Dirt Moving Old work horse 60’s , 70’s
   / Old work horse 60’s , 70’s #11
What痴 your storey with the super 90 ? How did you like it ?
I had just purchased some property that had been neglected for some time and was in need of some serious bush hogging. All I had at the time was a Farmall Cub.
I found the Super 90 27 miles away for $2000. It was in good shape plus it came with a 306 Bush Hog. Bought it and drove it home on the back roads, loved every mile of it.
It made short work of whatever I could ride over. Regrettably after I cleared everything I sold it for $2500 to a guy from Ohio, who sent a semi down to pick it up. Loved the low rpm power and the sound that motor made.
Now you got me wanting another older tractor.
   / Old work horse 60’s , 70’s #12
It has a dry clutch but locally I was a nice looking Ford 5000 the other day showing low hours that was a local sold tractor asking $8700. The shop that I use rebuilds a lot of older heavy tractors. They can be expensive to get fixed up but they will do a lot of work. Some are mainly pulling round balers more than for row cropping.
We have my father's 4500 Ford gasser which I will probably bring home just because it isn't worth anything. It's always been stored inside, doesn't have e lot of hours but hasn't been used much in the last 10 years so will need some work on soft parts; but when he tried to sell it a few years before he passed away the offers he was getting ($2-3000) made him put it back in the barn. I will get that much use out of it, and eventually sell my Kubota and get something smaller for when I want 4 WD.
   / Old work horse 60’s , 70’s #13
Massey Ferguson Super 9 Tractor - Shiloh, OH | Machinery Pete
If this is the super 90 you are talking about I see why you missed it. It seems similar to the 265 MF we have that the wife's dad bought new in 1976 and some kind of super heavy duty cutter like they use to clear under power lines, etc. I used it for the first time this year and cleaned up under the powerlines where they had a grinder in a few years ago so there stumps and things to watch. It is very stable on our hills due to its weight.
Of course it is a keeper due to the family connection but there are things to do where the 3000 and 3600 Fords just do not have the needed mass. I picked up a Cat 2 3PH forklift attachment for it last winter in Ohio and it does a great job of being stable moving heavy loads on the forks.
   / Old work horse 60’s , 70’s #14
Sounds like my late FIL's 1976 265 MF with 1400 hours. The heavy old iron that still runs well is nice to have around the place. They are over engineered to last compared to the newer stuff that is lighter for the boat ride. This Perkins engine can set for 6 months and fire right up. After we recover from rebuilding the engine in the 1948 Model B Allis Chambler this winter I plan to get it over to the same shop to see why the lift drops so fast when the engine is turned off and have it checked out in general since it is getting hard to find shops with skills for these old tractors.
   / Old work horse 60’s , 70’s #15
Couldnt get the link to work but tractordata.com has it listed.
The 200 series were good tractors I had a 245 for awhile.
Understand the family connection. Wish I had my grandfathers Jubilee, and my other grandfathers 140.
   / Old work horse 60’s , 70’s #17
Re: Old work horse 60痴 , 70痴
Look at older International tractors. They were great and can be had for pretty cheap and I've never had and issue getting parts for old Farmalls from our local Case IH dealer. 40+ year old tractors likely won't have a wet clutch.
If you're looking for an old plow horses in the 70-90 HP range look at Internationals models like 806/886/966/etc. These are good overall tractors with pretty heavy weight to them that can handle a lot of plowing.
   / Old work horse 60’s , 70’s #18
Those are the tractors I grew up on................I don't know the specifics for each model but I grew up on a lot of farmalls/ih and fords - my votes would be these 706 w/german diesel/I still own one ;-) - 806, 856, 886, 966, 986, a lot of them have dual pto, heavy built and reliable - you can go open station or cab, parts are obtainable for most any of them, I also grew upon fords that a farmer I worked for had they were great tractors also - 5600, 6600,7600,7700,8600 - my least fav was the 5600 only because it was underpowered and lighter for the work I tried to do with it when the other tractors were busy, I cant ever remember any of those tractors breaking, no I am not kidding, I just fueled them up every evening, checked fluids in the mornings, greased all the implements and then worked all day. I couldn't honestly say a bad thing about any of them. There were things I liked about some over others but all in all I wouldn't be afraid of any of them.
   / Old work horse 60’s , 70’s #19
Those old tractors came with a wide variety of upgrades and options. It was possible in the late 1950's to about the 1970s to buy a tractor with more features and of course they were way more reliable and featured more serviceable construction than anything built today. So much so that they are still easy to restore to full working condition.
The good old ones tend to have engines/transmission/running gear/hydraulics that are all on good shape. What they tend to need is rubber parts, electrical, and cleaning out the fuel system. And brakes...
So I'd say that the person who finds a good old machine and doesn't mind the work to return it to good shape is likely to save himself some serious money and end up with a better machine. Parts seem to be available for about everything. However, factory options and upgrades are hard to find - so I'd recommend buying a "loaded" tractor if you can.
Our old JD makes a good example.
This 1958 JD530 has the last incarnation of the two cylinder "B" engine. It's hard to imagine a nicer motor. Starts right up, idles at 200 RPM, pulls like a truck, and has modern hydraulics with a hight flow rate and multiple remotes for accessories. The seat has suspension, springs, and damping. Power steering is very smooth.
The wide front axle can be widened or narrowed. Same for the tire width on the rear - which has a gear drive system for adjusting tire width! It also has the optional single front wheel for row crop work.
The Factory Loader is a quick-attach type that removes with 3 bolts & will easily lift a round bale. It comes with several interchangeable buckets and front tines for different loader jobs.
The three point is pure joy. Smooth operation. Category I and II, telescoping adjustment, variable draft control, and will lift heavy implements up high and hold them there all day. The PTO has it's own lever for engagement as well as its own clutch completely independent of the rest of the tractor. That heavy PTO shaft with it's oversized bushings coupled with the engine's huge radiator and oil reservoir means that this tractor is happy being used as a stationary engine for water pumping and other chores. When we got it the farmer had been using the tractor as an irrigation pump for a corn field. For years....
It doesn't have a cab, but JD makes a clever heavy duty canvas umbrella that mounts right in a socket on the side. I had my doubts about that umbrella, but it turns out to be wonderful - as well as a conversation piece.
We've had the JD530 in constant use for about 30 years now. It had about 12,000 hours on it when we got it and no telling how many since. It hasn't asked for much...a new gas line, carb cleaned, seat cushion, brakes, clutch cleaned out...that kind of stuff. Oh...and a new combination tach&hour meter. I opened the old one to see why the needle was drooping, and found a beautiful clockwork mechanism of gears and springs, but with bronze needle bushings that had completely worn out. The hole in the bushing was worn oval instead of round. I guess I could have sent it to a watchmaker for repair, but a brand new combination gear drive tach/hour meter only cost $120.00 and was in stock at my local dealer! I kept the old one just to admire the beauty of the mechanism. The tach drive and cable are still original.
The brakes and clutch are very accessible. Instead of being hidden within the body of the tractor, but the brakes and clutch are geared to the transmission countershaft so they can be mounted on the side of the tractor. So the brakes and clutch can be serviced with hand tools while standing next to the tractor. Of course mounting systems accessible like this is a much more expensive way to build a tractor; it was done that way because owner convenience was a major selling point at the time.
There's a lot of reasons to like those old tractors. They don't cost much, are easy to keep going, and they'll certainly do the work.
rScotty
Thanks to everyone . We are hearing some great stories. I appreciate you guys sharing, please continue.
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
2013 International DuraStar 4300 Altec L42A 42FT Bucket Truck (A55852)
2013 International...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
1996 FORD F-SERIES FLATBED TRUCK (A57192)
1996 FORD F-SERIES...
2005 Ford F-750 Truck (A53422)
2005 Ford F-750...
2020 PETERBILT 567 SLEEPER TRUCK (A56138)
2020 PETERBILT 567...
