Hi, I'm needing advice on a John Deere MX 8 mower.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #1
Steve E H
John Deere 4020
Hi, I'm needing advice on a John Deere MX 8 mower. I saw this site in my search and thought it may be helpful for a variety of reasons.
Concerning the MX 8 mower, t has a single acting hydraulic cylinder to lift the rear wheels. When the hydraulic cylinder is fully extended, hydraulic oil spews out the plug at the end of the cylinder. I am needing ideas on what exactly could be wrong and what is needed to fix this problem.
Thank you.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #2
I’m guessing it doesn’t have gland seals or very good ones and the rod seals are shot. When you deadhead the cylinder the oil pushes past the worn seals.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #3
:welcome:
Welcome to the forum!
I'm going to move this thread over to our John Deere section.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #4
Don't mean to hijack thread, but related questions: Does the "back side" of a single action cylinder, that doesn't normally see pressurized fluid, need to be vented?
Can a double action cylinder be made into a single action cylinder by using one line? If so, does the "inactive side" need to be vented or plugged?
   / Hi, I'm needing advice on a John Deere MX 8 mower. #5
Thank you.
A pic will help see what you refer to here, but there should be no fluid spewing out.. More specifics will help answer your question.
:welcome: to TBN
   / Hi, I'm needing advice on a John Deere MX 8 mower. #6
A double acting cyl can be utilized as a single acting cylinder by removing one hose & installing a breather.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #7
Ditto cyl piston seals have failed.
2020 Gehl RT105 Skidloader (RIDE AND DRIVE) (A50774)
2020 Gehl RT105...
750 Gallon Concrete Fuel Tank (A50774)
750 Gallon...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
Cat TH407C Telehandler (A52748)
Cat TH407C...
