Hi, I'm needing advice on a John Deere MX 8 mower.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #1
Steve E H
John Deere 4020
Hi, I'm needing advice on a John Deere MX 8 mower. I saw this site in my search and thought it may be helpful for a variety of reasons.
Concerning the MX 8 mower, t has a single acting hydraulic cylinder to lift the rear wheels. When the hydraulic cylinder is fully extended, hydraulic oil spews out the plug at the end of the cylinder. I am needing ideas on what exactly could be wrong and what is needed to fix this problem.
Thank you.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #2
I’m guessing it doesn’t have gland seals or very good ones and the rod seals are shot. When you deadhead the cylinder the oil pushes past the worn seals.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #3
:welcome:
Welcome to the forum!
I'm going to move this thread over to our John Deere section.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #4
Don't mean to hijack thread, but related questions: Does the "back side" of a single action cylinder, that doesn't normally see pressurized fluid, need to be vented?
Can a double action cylinder be made into a single action cylinder by using one line? If so, does the "inactive side" need to be vented or plugged?
   / Hi, I'm needing advice on a John Deere MX 8 mower. #5
Thank you.
A pic will help see what you refer to here, but there should be no fluid spewing out.. More specifics will help answer your question.
:welcome: to TBN
   / Hi, I'm needing advice on a John Deere MX 8 mower. #6
A double acting cyl can be utilized as a single acting cylinder by removing one hose & installing a breather.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #7
Ditto cyl piston seals have failed.
2014 Ford F-250 Extended Cab Knapheide Service Truck (A50323)
2014 Ford F-250...
Genie GTH1056 (A50120)
8ft x 6ft Container with Side Door (A51573)
8ft x 6ft...
2013 John Deere 824K (A52748)
2013 John Deere...
Howse 10' 3pt Rotary Mower (A50774)
Howse 10' 3pt...
John Deere 300 Tractor W/Loader (RUNS) (A50774)
John Deere 300...
