How to fix my leaking throttle valve on lucas cav injector pump on my john deer 410B
   / How to fix my leaking throttle valve on lucas cav injector pump on my john deer 410B #11
1stNuff. depending on the mdl of inj. pump you have, the fuel out of the pig-tail is supposed to drain out..
SOME pumps are fuel oil lubricated.. while others are engine oil lubricated.. IF yours is the engine oil type, when was the last time you changed the oil, checked the level or added oil??
If its the fuel oil lubed system.. don't worry about it.. its doing exactly what its supposed to do.. unless of course its "streaming" out.. dripping in ok..
   / How to fix my leaking throttle valve on lucas cav injector pump on my john deer 410B #12
I am doing this with Ford parts on my old 1975 Backhoe.
Is there a better gasket and o'rings than OEM? I have to wonder if these Ford o'rings are safe for the new diesel
Ford pt # gasket 384771R1 and Orings - Ford pt # 49886
Where is the bleeder on the pump itself?
   / How to fix my leaking throttle valve on lucas cav injector pump on my john deer 410B #13
Ford isn't the OEM on those parts. CAV is..
You can buy the whole mini kit to do the top cover for 6.00 w/ free shipping..
don't forget the fiber washers that go under the top nuts.. they WILL leak..
U paid 13.00 for the gasket alone.!! you coulda got ALL of it for 6.00 on ebay..
   / How to fix my leaking throttle valve on lucas cav injector pump on my john deer 410B #14
Actually it was $11.77 for everything delivered from the local dealer.
Now I have a new issue -
My Fuel inlet is leaking on my 1975 Ford backhoe. Do you have a part number for that? I haven't found anything in searches.
Is that part rebuildable? Wondering if the stuff to rebuild it comes in the kits as I haven't seen that part for sale yet.
It has the numbers 7167 cast on the top inside and 272 JD2 on the bottom inside
I also need a new gasket which I have seen in all the kits.
My pump looks like this one with the fuel line going where the white plug is.
FORD 46, 461 TRACTOR W/21 ENGINE DIESEL FUEL INJECTION PUMP - NEW LUCAS CAV | eBay
   / How to fix my leaking throttle valve on lucas cav injector pump on my john deer 410B #15
The entire gasket kit is 7135-110 it has 99-100% of the gaskets you'll need..
"patching" a CAV pump is NOT recommended.. they leak somewhere else, as your finding out..
Its BEST to go all the way thru one, the first time..
The bleeder screw is by the name plate on the side.. its a double screw.. 5/16 bleeder in a 7/16 body..
Just loosen the 5/16 screw, SPIN/CRANK THE ENGINE until clear fuel comes out, NO AIR, & tighten..
   / How to fix my leaking throttle valve on lucas cav injector pump on my john deer 410B #16
Has anybody put a lift pump in front of these before?
Would there be any advantages?I was thinking about using a lift pump off a GMT400 6.5 diesel
Are the new gasket kits ULSD friendly?
I still have yet to find the fuel intake plate. On mine the part the incoming fuel line screws into, is spinning in the plate. The gasket was not leaking.
The gasket will have to be replaced now that I have it apart.
I haven't figured out why the fuel inlet plate is made in 2 pieces like it is. It seems it could have been one piece I'm beginning to wish I had some of the aircraft fuel tank repair epoxy. That would fix that leak.
   / How to fix my leaking throttle valve on lucas cav injector pump on my john deer 410B #17
You don't know how it works.. sorry to say..
The "plate on the side" IS NOT the inlet.. its the return.. The inlet is to the right ..
The plate back in the 70's were made of 2 piece aluminum w/ epoxy holding it together.. after 40 years its broken down..
The NEW plates are 1 piece metal.. I need the pump P# inorder to give u the correct P#.. there are diff. ones..
   / How to fix my leaking throttle valve on lucas cav injector pump on my john deer 410B #18
Ok Thanks. I wish I had more epoxy. I'd just fix the piece I have. I used a 3M product -AC236 - to seal the leaky axle tube on the 1996 Toro 223D. Worked great.
I am looking into keeping something on hand. When I was looking for that product, I had trouble finding stuff that was resistant to the new diesel, transmission fluid, dissimilar metals - steel and aluminum and vibration
3M AC-730 B-2 is another product I looked into
3M Aerospace Sealant Kit | AC-73 B-2 | RS Hughes Industrial Supply
   / How to fix my leaking throttle valve on lucas cav injector pump on my john deer 410B #19
WE use a special 2prt epoxy in the fuel inj. industry.. its made by Armstrong & costs 65.00 a set. BUT u cant buy just 1 because they have a min. order.. Ya gotta get 2.. lol
I've "fixed" MANY side covers using it. but it sounds like you NEEDED a cover, seeing your housing pressure regulator check ball was missing..
   / How to fix my leaking throttle valve on lucas cav injector pump on my john deer 410B #20
Neither Rick nor I knew if every cover had a check. I have to wonder how long the ball and I assume spring has been missing and where they went.
I was hoping that some never had a check to begin with and mine was one of those. LOL
I bought the stuff I got from aircraftspruce.com I believe I could have got the 3 M products at a lot of places.
The numbers I got off the injection pump - to the best as I could - DPA 3233F640 The 2nd 3 looked like a 3, but was different from the other 3's. The 4 was smaller than everything else & looked like it could have been a plus sign
Serial 49337 OS
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2015 VOLVO TRUCK VN SERIES (A50854)
2015 VOLVO TRUCK...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2013 Dodge Journey SXT (A50324)
2013 Dodge Journey...
