There Is No Compass In My Pickup
   / There Is No Compass In My Pickup #1
HillStreet
Maine
Kubota B2650HST. Kubota Z125S
I drive a 2015 Tacoma and it does not have a directional compass. It痴 a nice truck with good radio but there just is no compass anywhere. I can navigate just fine without it, but I would every now and then like to know my direction reference to where I am and where I知 going. When I fly I am always aware of my location and direction so it does bug me sometimes that I don稚 have that information.
   / There Is No Compass In My Pickup #3
I have one similar to this on an inherited vehicle. Don't use it much (I keep it covered with a hat, partly to reduce sunburn), but it's nice to know it's there.....
Dash Mount Traveler Compass
Probably not that easy to find on a retail shelf - marine stores might be an possibility, but I suspect they focus more on the expensive bulkhead ones.
Rgds, D.
Thanks for the replies and recommendations. I will get one of these but I just cannot figure why the **** Toyota wouldn’t install one into the dash, or the mirror.
   / There Is No Compass In My Pickup #5
There may be a higher trim model that did have a compass in the mirror. You could retrofit that. Check the tacoma web sites to see if someone's done that and posted instructions. It'll be a lot more expensive than a simple dash mount compass though.
   / There Is No Compass In My Pickup #6
When I traded a 2004 GMC for a 2009 Tacoma I figured that was no big deal. GMC had on in mirror and Tacoma didnt have one. But that got on my nerves alot....so did alot of things. The Toyota was a reliable truck, but it was underpowered and un ergonomic. It also felt like it was a little too big for its britches compared to an old sr5 pickup.
   / There Is No Compass In My Pickup #7
For years I had vehicles with no compasses. I tried a mechanical one, but it was not reliable, I bought an electronic one and it was not reliable, I bought an after market rear view mirror compass/outside temperature thermometer and it was semi reliable until it died. The best solution I've found is a dash mounted GPS. You can buy an older model off eBay for a few bucks, plus you have maps.
   / There Is No Compass In My Pickup #8
Even a new GPS is cheaper than a marine compass, if I am a long way from areas I know I just look for the general direction of the sun (even on overcast days) and the time.
   / There Is No Compass In My Pickup #10
Manufactures realized trinkets like a compass or turn signals mean nothing to a generation of drivers raised in the back seat, deleting them means more profit to keep the investors and board happy.
Heavy-Duty D-Ring Shackle Set (A53117)
Heavy-Duty D-Ring...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
