Crack Pipe Lighters
/ Crack Pipe Lighters #1
Alan W.
Kentucky
Kubota L3650 & Bobcat 763G & Craftsman DGS6500
I have found the crack pipe lighters that are sold at the local gas stations, while I have not tried them for their intended putpose, are great for starting fires, heating heat shrink tubing etc. The problem I am having is when I refill them with the butane I have they quit. I called the phone number on the butane canister and was informed that the butane I had was not a good match for those lighters.
I thought butane was butane, but the rep informed me that unlike propane, butane has different formulations by manufacturer.
Anyone ever heard of this
/ Crack Pipe Lighters #3
Yep! I use the liquor store crack lighters for my crack smoking all the time.
I just knew I shouldve posted this question in High Times instead😎
/ Crack Pipe Lighters #7
Is the idea of the lighter to melt the crack in the pipe back together so it does not leak? I cannot see that working, but maybe if really, really hot.
/ Crack Pipe Lighters #8
Yes, that is what he is talking about...... Not! :mur:
/ Crack Pipe Lighters #9
I think you guys are missing the point - - now, where was that point, the last time I saw it??? OH - is that it out there in the field with the pallets???
/ Crack Pipe Lighters #10
This
What is different between N butane and ISO butane?
As nouns the difference between isobutane and butane. is that isobutane is (organic compound) a hydrocarbon, a particular isomer of c4h10 found in natural gas while butane is (organic compound) a hydrocarbon (either of the two isomers of c4h10 n-butane, and 2-methyl-propane) found in gaseous petroleum fractions. isobutane. English. Noun.
is probably what he was referring to, which may or may not be germane to what you asked him.
Source:
wikidiff.com/isobutane/butane
/ Crack Pipe Lighters #12
I have never had good luck refilling those refillable butane lighters. I don't know what the problem is, but they just don't like to take on fuel from one of those butane refill containers. I had one lighter while in my 20's that worked for a while but it eventually also quit taking butane. I now just stick to the Bic lighters.
/ Crack Pipe Lighters #13
I thought the procedure was: Put butane refill cylinder in coffee can with small amount of gas. Ignite gas with crack lighter. Stand back and wait for large fireball.
No experience admitted.
/ Crack Pipe Lighters #14
I have not needed to carry a lighter in many years, but the old tried and true refillable Zippo has always been my favorite. I've never had much luck with refillable butane lighters and gave up on them a long time ago. The disposable Bics were OK though, and usually in every store you walked in. However they often walked away from me after a while, requiring the purchase of another one. I don't think I ever ran one empty.
/ Crack Pipe Lighters #15
Now that some real PARTY POOPERS have actually tried to answer the question I’ll chime in-
I’d skip the refillable butane torch and get the little torch that converts a standard lighter into a torch. A buddy of mine who did high end electrical (rockets, satellites etc) turned me on to them. He used it for heat shrink etc. The lighters can be had about anywhere and keep for years. Refilling never seems to pencil- something always seems to go wrong after a few fill-ups.
/ Crack Pipe Lighters #16
I'll carry a Zippo from now until next summer to start fires in the wood stove and for lunch fires... it fits perfectly in the watch pocket of my jeans. The downside is that it needs to be filled twice a week whether I use it or not. I must be uncoordinated because trying to light a butane has always been hit or miss, especially with cold wet hands. With the Zippo I can gather my fire material, prop the burning lighter on the ground, and feed the tinder to the flame.
/ Crack Pipe Lighters #17
I liked my Zippo, but it seemed to always be out of fluid. I usually just carry a bic now. Btw, I don’t smoke but need a lighter pretty frequently.
/ Crack Pipe Lighters #18
I liked my Zippo, but it seemed to always be out of fluid. I usually just carry a bic now. Btw, I don稚 smoke but need a lighter pretty frequently.
Funny story on Zippo. I found a Zippo on the edge of the road near my house; it had been run over several times and was pretty banged up. I took it home and forgot about it. Some months later, I received a package in the mail, containing a new Zippo. Turns out, my young daughter sent the old one to Zippo asking if they could "fix her Daddy's lighter". They sent me a new one instead!
/ Crack Pipe Lighters #19
What I'm using now:
Tech Torch Auto Start Butane Torch Kit | Princess Auto
Used a no-name version of same for several years, until the regulating (adjustable) valve started leaking. Always used Ronson butane refills, and never had an issue with ignition.
It is convenient for tasks already listed, and I like how compact it is, for working in tight spots.
Rgds, D.
/ Crack Pipe Lighters #20
They have or had a lifetime guarantee. I remember one ad from years ago about somebody who lost his lighter while fishing, found it about 40 years later and got it refurbished. They also are advertised as windproof... what a freaking joke. :D
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2022 Morbark Eeger Beever 1215 Towable Brush Chipper (A59228)
2022 Morbark Eeger...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
UNUSED IRANCH MINI EXCAVATOR RIPPER (A60432)
UNUSED IRANCH MINI...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
