Mustard yellow gear oil.. Help please
   / Mustard yellow gear oil.. Help please #11
fill that sucker with diesel/kerosene/paint thinner whatever u have around, the blade around a few times and then use that loader in your picture to turn it over and drain it out, no sense in beating this horse.............that's what loaders are for is for doing things like this ;-) and you tell your wife honey I sure am glad I have that loader it saved us a bunch more $$$ today!!!!!
   / Mustard yellow gear oil.. Help please #12
^^^ this.
I guess Ill have to do that.. **** thing weighs a ton but I have plenty of chains and straps.
Its crazy that these shredder mfg’s allow no means to drain the boxes.. Maybe the newer ones???
Thanks for the ideas gents.. Ill have to putt my thinking cap out to rig the lift safely..
   / Mustard yellow gear oil.. Help please #14
I replaced some seals on my Woods mower a couple of years ago and removed the blades, disconnected the driveshaft and unbolted the gearbox from the mower. I then dumped out the gear oil. IIRC it wasn't too difficult to remove the gearbox.
   / Mustard yellow gear oil.. Help please #15
I wanted to say this as well. I've had some gunky gearboxes that were full of crud and found they were not that bad to R & R.
   / Mustard yellow gear oil.. Help please #16
cavjock - you only have to lift up one side of it, chain it on one side and then lift/drive forward it will stand up with the bottom edge on the ground then you can just let it down after it reaches the tipping point, if you have a tree you can put a chain on the tree to hold it from slamming down or if you are worred about it pulling you and the tractor forward as it tips downward.
shouldn't be too difficult to roll it over and I am surprised there is not a drain on it, it might be up underneath of the stump jumper you might find that after you get it up in the air.
otherwise - roll it over
   / Mustard yellow gear oil.. Help please #17
Rather than use an oil based product to clean it out, I suggest using something that mixes with both oil AND water...alcohol. Fill it with isopropyl alcohol and run it a little then dump it. Repeat until it comes out clean.
Thanks for all the suggestions. I spoke to the Bushhog Factory Service rep the other day. He said those gearboxes are very well known for getting moisture in them with just normal use. He even made the comment that I can go to all the trouble to change oil but chances are I値l have a little bit of moisture in there in 12 months again. He said sucking out the amount of fluid that I can and replacing with new is more than adequate. The new oil壮 have plenty of additives to fight off the moisture as long as youæ±*e using quality oil.
With that statement he got me thinking about using yamaha outboard gear oil. Itç—´ designed to not mix with water. Since itç—´ used in lower units of outboard engines water is very frequent. maybe even using a 50-50 mix of this with regular gear oil. I will be curious to hear the comments on my idea. Desk below of outboard gear oil....
The gears inside your lower unit are constantly turning, and the only protection they have is the lower unit lubricant you use. Its job is to form a micro-thin film between the metal component parts to keep them from actually touching. Under the large loads these gears exert, proper lubrication requires extreme resistance to pressure, foaming and molecular shear. And, since the lower unit operates underwater, its lubricant also has to be capable of maintaining necessary lubricity even when a significant amount of water is present, should some leak inside. Ordinary gear lubricant can稚 do all of this; so always avoid automotive or tractor gear oils. Use a quality, marine-based formula, like Yamalubeョ Marine Gearcase Lube. It can perform all of these required protection and lubrication duties, even with a full 10% of water present. There痴 even an HD formula,
   / Mustard yellow gear oil.. Help please #19
Outboards also get moisture in the lower units and it is also common. They also suggest you drain it once a year.
   / Mustard yellow gear oil.. Help please #20
I would go with the gear oil it's supposed to have but maybe a synthetic. It will be fine if the rep thinks it will be fine.
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2011 John Deere 4520 53HP Loader Utility Tractor (A51691)
2011 John Deere...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
2006 iDrive...
Genie GTH-644 (A50490)
Ford Tractor (A50120)
