Mustard yellow gear oil.. Help please
   / Mustard yellow gear oil.. Help please #21
Rather than use an oil based product to clean it out, I suggest using something that mixes with both oil AND water...alcohol. Fill it with isopropyl alcohol and run it a little then dump it. Repeat until it comes out clean.
See post #7 for this suggestion.
   / Mustard yellow gear oil.. Help please #22
Not sure I view outboard lower unit oil as being any better. If you drain a lower unit and there are signs of water (milky, etc) then you got big problems. I don't think anybody ever feels like they are OK in that situation, or that the special gear oil was helping.
Point well taken
   / Mustard yellow gear oil.. Help please #24
Per my post inn the attachment page. I bought a used Bushog 3210 shredder. I knew the gear boxes had water when I purchased. Figured I would drain or suck out and all good..
I spent most of yesterday doing that. I would run about 30 minutes then suck out the oil with a marine engine oil pump. I went through 5 gals of oil and could not get the oil to look any better. Short of lifting the cutter and laying down upside down.. I don’t want to do that.... What are the suggestions of getting rid of the water/oil mix that’s below the gear box that I cannot suck out?
Kerosene or Diesel is what I read to use but then how do I get that out?
Oh and by the way gear oil stinks......lol
Help appreciated..
These gearboxes are so understressed in the average mode that a water oil emulsion is not much of a problem. My JD bushog is almost 60 yrs old. It has had a very hard life, most with some water contamination. The gearbox has never needed work. At this point the seals dont hold oil so I use light grease in the box. Cornhead grease is optimal.
Good info.. I’m going to quit worrying and get to shredding.. Ha thanks..
(4) 64" X 40" ALUMINUM POP-UP SIDE WINDOWS (A51248)
(4) 64" X 40"...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2012 Nissan Maxima Sedan (A51694)
2012 Nissan Maxima...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
