Pittsburgh 1 1/2 Ton Aluminum Racing Jack Leaks
   / Pittsburgh 1 1/2 Ton Aluminum Racing Jack Leaks #1
AchingBack
Southern Oregon
Mahindra 2615HST
Has anyone rebuilt or repaired this jack? Mine is leaking at the bottom of the rods going through the springs. I guess there must be some failed O-rings, or seals.
Without some guidance, I can't see how to properly tear it down. 1.5 Ton Aluminum Racing Floor Jack with Rapid Pump(R)
   / Pittsburgh 1 1/2 Ton Aluminum Racing Jack Leaks #2
I have one, as far as I am concerned its junk... Will hardly lift corner of Chevy PU to change a tire...
But if you must....
https://manuals.harborfreight.com/manuals/60000-60999/60569.pdf
Note this statement in PDF file... IT probably in reference to part you need to repair....
572910d1538333125-pittsburgh-1-1-2-ton-jack-jpg
Dale
   / Pittsburgh 1 1/2 Ton Aluminum Racing Jack Leaks #3
But if you must....
Mine lifts my big Thunderbird with no problem.
Dale
Thank you, but I already have this and it isn't helpful. Mine works when properly bled and refilled. It just leaks soon after.
If you search it on u-tube you might find some information about them... Worth a shot.
Lots of videos there on other floor jacks, but all of them are of a different configuration.
   / Pittsburgh 1 1/2 Ton Aluminum Racing Jack Leaks #6
   / Pittsburgh 1 1/2 Ton Aluminum Racing Jack Leaks #7
Seals are pretty generic. If you can get it apart, you can probably find an appropriate seal at McMaster-Carr.
Thanks. At this point in time it is easier to deal with refilling and leaking. I don't have the time to tear into it without guidance.
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
ALLISON TRANSMISSION (A53843)
ALLISON...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
