455 Mower dies after blade change
   / 455 Mower dies after blade change #11
Does the PTO work with the deck driveshaft disconnected while sitting on the seat?
You can turn the driveshaft by hand I take it. Could it be something not part of the deck such as a safety switch?
It doesn't seem to me to be in the deck.
The PTO works. My FIL disabled the seat switch when he owned it, which makes it easier to check things like that. I'm not sure of the mechanics of it, but the blades would tighten up when I engaged the PTO. I noticed that they were a whole lot tighter trying to remove them after putting them on. The 455 fits in a trailer, so I can take it to the shop. I still have maintenance to do on the MF135 and the Ford 4600, so I don't feel too bad about this one.
   / 455 Mower dies after blade change #14
Compare the assembly diagram with how your blades are mounted. Also check the thickness of the new blades compared to the old ones. OEM JD blades are usually 1/4" thick. Many non-OEM blades are 3/16" and require spacer washers to get the blades to be tight. This could account for the bolt 455-48.JPGtightening issue.
   / 455 Mower dies after blade change #15
Do advise the mechanic to report the cause so we can know the fix. Before I would take it in I would take the blades off totally and see if the deck would run like it is supposed to. It won't hurt anything.
Well, neither I nor the mechanic knows what is going on. I had the blades mounted upside down. He flipped them over, put it back on the tractor and hooked up the PTO. It started right up. The blades look the same in the mounting area - nothing raised on either side. I mowed 2 acres today with no issue.
   / 455 Mower dies after blade change #17
Sounds like the upside down blades bogged it down
   / 455 Mower dies after blade change #18
Will be good for you to find out what was wrong.. there is nothing magical about it.
Surprised your "mechanic" didn't see it and/or let you know.
Just curious to know more too...
I don't understand how the blades being upside down did anything. It's basically flat bar stock. They turned backward just fine, but locked up turning forward.
   / 455 Mower dies after blade change #20
I think you are correct.. so find out what wasn't correct that actually caused the binding..
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
2021 John Deere 9420R Tractor (A53342)
2021 John Deere...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A51572)
2013 Dodge Charger...
