Geotech
Man oh man - there is such parity in this market that it is hard to make a final decision. I was pretty set on Kioti for the value proposition and the stronger loader specs (the CK2610 now comes with a 1800ish lb capacity loader - about 400 lbs more than the Kubota at the same position). I wonder how much real world difference there is between these loaders? And the Kubota is hard to resist!
I got a quote for an L2501 that the dealer says is good till the end of the year. For the HST 4wd tractor, loader, land pride rotary cutter (slip clutch model) and land pride box blade I was quoted $21,446 out the door.
A similar package with a CK2610 would probably run about $2000 (+/-) less based on previous quotes I've received for that machine. Financing is better with Kubota.
I will also be getting a third function and a grapple. 3rd functions generally cost about $1000 for any dealer for any brand around here. An EA attachments grapple would be $1850. So adding a grapple is going to cost around $3000.00. I think land pride has a slightly cheaper grapple - but it is slightly not as good as the EA grapple...Still, I could probably live with the land pride grapple and it would be convenient to wrap it up with the tractor package.
What do you all think about the quote on the Kubota? Any suggestions on how I can negotiate a lower price on the overall package?
