Starting our new life
   / Starting our new life #451
Are you using Comp Shingles and if you are is there any issue installing in cold weather?
Long time ago I was told at a certain point it can be too cold?
They are the architectural grade shingles 35ish year warranty.
I was told as long as the temp's get to 45 degrees they will tab down. Next week is supposed to be around 50 degrees and the fact they are very dark I think I'll be fine.
   / Starting our new life #453
I thought of you this last week as I drove up the I-15 through southern Idaho heading to the I-90. I kept looking out over the fields for new construction, :laughing: I'm glad things are moving along so well for you!
Thanks joeyd,
So far it seems I'm waiting for parts/supplies more than subs. I'm waiting for doors/windows right now, will be another week at least.
FYI... I'm located northwest of Bear Lake.
   / Starting our new life #455
I'm surprised that you are using shingles, did you look at steel?
   / Starting our new life #456
When I re-roofed my house I was talked out of metal. The roofers said there is too much moisture buildup under metal roofs in my (wet) climate. I do not know what the correct story is but the composition roof I had put on may outlast me anyway.
It also seems metal would be hard to walk on when wet, but composition still gives you traction.
I was going to use steel but was talked out of it by several different builders. If the roof had straight drops (no valleys) then metal would have been the way to go. My roof has valleys and the freeze/thaw cycle gets under the metal. That's why I'm not using metal.
   / Starting our new life #458
That makes sense. Diligence is required in valleys.
Here's some pictures of the fireplace. On the back the bigger line is combustion air, the other one is cooling air for the flue pipe.
The last picture is why we need a fireplace to begin with.:laughing:
   / Starting our new life #460
Would you ever need to get into the space behind the fireplace?
I have bought homes where rodents gnawed through heater ducts and made a mess... one was in a concealed space.
Anything I do in concealed inaccessible areas is with hard duct as a precaution...
Not saying your area has a rodent problem but it looks like significant space being walled up.
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
2014 Jeep Compass Multipurpose Vehicle (MPV), (A51694)
2014 Jeep Compass...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
2025 Mower King SSECAG-Y Hydraulic Auger Skid Steer Attachment (A50325)
2025 Mower King...
2002 Freightliner FL70 Elgin Street Sweeper Truck (A51692)
2002 Freightliner...
