Are you positive you have hyd pump oriented correctly? I've never seen destroking screw pointing down or stroke control adjusting screw pointing up on JD frt hyd pumps.
This scares me. The pics in the book show as you describe. The fittings on the used pump I got are in the same positions as the fittings in my pump. So that would make the pump oriented the same as what I took off."
I questioned the guy I got the used pump from and he said the back of the pump could not be rotated and the oil ports would not line up.
I'll have to dig deeper before I install.
Would the pump work if the back plate was rotated 180 degrees?
i AM ASSUMING THE PUMPS ARE IN THE CORRECT CONFIGURATION. We went down and looked at the neighbors 4010 and his pump is the same as these 2. So we are 3 for 3 all the same.
When we checked the screen in my old pump there were grooves wore into the rin from the spring.
The used pump I got makes a clicking noise when you turn it by hand. I am wondering if that pin also has grooves wore in it and the spring is clicking
Looking for the torque spec for the inner tie rod end bolt - You have a range of 55-80 ft.-lbs.
Tighten to 55 ft.-lbs. If the slot for the cotter pin lines, install it. If not, continue tightening to line up the nearest slot. 80 ft. lbs. would be the max torque, to line up slots.
and the small 5/8 bolts that hold the front plate on. The 3/4" bolts I have at 300 ft lbs.
