BigBlue1
The only time I've seen 8-10 v-belts is on a pto pump for irrigation. The belts were rather narrow and the setup was designed to handle about 80 hp. I think that you are thinking of fractional hp belts or automotive ones. There are also B,C and D sizes. A double C belt easily handled 60 hp when the above pump was run on an engine pulley setup.
Harley Davidson and other manufacturers are using toothed belts instead of chains for the final drive on their motorcycles. They have for years already. Toothed belts and serpentine belts have similar construction. I wonder what the torque is going through a Harley drive belt at full throttle in first gear?
Automotive applications went to serpentine belts for several reasons. One belt could do the same job as two or three and they are more efficient. They also take up less space for the same power requirements.
No idea about Harleys but a Victory Cross Country puts out 80+ HP to the rear wheel via a toothed drive belt (from close to 100HP engine). Also, snowmobiles use a belt drive system and routinely run well over 100HP.
In fact, what if you used a whole belt/clutch primary/secondary system from a snowmobile to power the generator? That setup has infinitely dynamic gear ratios that may allow you to overcome the initial spin-up issue and they automatically 'free wheel' when the engine goes back to idle so that may resolve the overrun clutch need.
Rob
