Grading Is a GC1705 box blade combo going to work?
/ Is a GC1705 box blade combo going to work? #1
ohmyback
Missouri
JD 750 GC1705
Hello All,
I have a GC1705 and need to do some grading on my established driveway. Just trying to decide if buying a box blade is worth it. I do have the FEL. I would like to remove the crown and fill some low spots.
Just don't know if I am going to make more work with a box blade. Other thought was to put some teeth on the bucket. Years past I always used a bobcat that I no longer have. Last option is just buy
another load of gravel. All three options at this time are about the same dollar spend. Anyone have some first hand experience with the GC tractors and grading?
/ Is a GC1705 box blade combo going to work? #2
I ended up getting a 48” SBX which for the dirt work I planned and plan on doing with it works well, granted if I fill that box up I have trouble pulling it. If I was going to be working a driveway I’d probably get the lesser weight version. Box weight is a balancing act, you want weight on the shanks for ripping but too much and your tractor can’t pull it full. Doing it again I’d go lighter than the sbx line and add weight if needed.
If you find yourself spinning the rear wheels you’ll need to add weight. I have a 130lb weight in the mower arms, beet juice filled tires, and an additional 130lb weight by my feet when I’m pulling the box blade. If you are stalling your tractor at full throttle you’ve found a good amount of weight!
/ Is a GC1705 box blade combo going to work? #3
I found a used back blade for $100 and after getting some good advice on this forum this week found it did a pretty good job of grading my drive way. The secret is to wait for some moisture and to angle the blade at 45* for the initial passes. Then use the blade turned 180* so the back of the blade is used for finial smoothing. It is not perfect but I am still learning.
I came really close to buying a box blade after reading many threads here. But it seemed that unless you have a hydraulic top link, they are a bit of pain to use. And I have no need to move material from one place to another which is one feature the box blade has.
The other option is a land grader/leveler. Just seemed too expensive for my needs as my driveway is only about 200 yards long. I am in a rural area and my driveway is actually in better shape than the road to my place. Seems silly to pay for perfection in my case.
Thank you for your responses.
/ Is a GC1705 box blade combo going to work? #5
Get a 48" boxblade with scarifiers and you will not be disappointed, A little practice is needed to reduce rippling, and being too aggressive with the scarifiers. Mine is always left on to provide a counterweight for loader work. Greatly increases the stability of the GC and adds traction to the rear tires.
/ Is a GC1705 box blade combo going to work? #6
I have a Woods 54" road grader that I use with my 1720. I leave the scarifiers off normally, it pulls fine, we have about 1000 feet of gravel drive.
/ Is a GC1705 box blade combo going to work? #7
Hello All,
I have a County Line 48inch BB and it is awesome, I love the reverse and forward blades. Helped me move and level 30 plus 18 yeard dump truck loads of gravel, sand and loam. I usually run out of traction before the tractor limits while using the spikes, I have turf tires.
/ Is a GC1705 box blade combo going to work? #8
I have since added a hydraulic top link and it makes pulling the box so fun!
I find it intriguing how you can also adjust the side link and put a perfect pitch on a trail/drive to flow water....the whole grader box application is addicting....at least for me.
/ Is a GC1705 box blade combo going to work? #9
I’ve been thinking about a hydraulic top link for this reason. Can you elaborate on your install? Where did you get the parts, what valve did you use, etc...
/ Is a GC1705 box blade combo going to work? #11
Thanks. Looks like the top link is no longer stocked.
/ Is a GC1705 box blade combo going to work? #12
Just source a ram with the same dimensions elsewhere, actually if I did it over again I’d probably shorten overall retracted length by an 1”
/ Is a GC1705 box blade combo going to work? #13
Just source a ram with the same dimensions elsewhere, actually if I did it over again I壇 probably shorten overall retracted length by an 1納/QUOTE]
dneal, I hought I found the same top link on the Surplus Center site just yesterday but maybe I was wrong. GC1710, I noticed that the retracted length of the manually adjusted top link on my tractor was about an inch shorter than the cylinder you used and I was wondering if it made any practical difference. Sounds like it might and thanks for your comment on it.
Also, I see that SC offers a version of the valve that has a float position for an exrea $100. I知 trying to think of a case where a floating top link would be useful?
/ Is a GC1705 box blade combo going to work? #14
A side-link float option would be good for following ground contours. I’m sure there is some top link float reasons, but I can’t think of any.
Thought I would post a before and after picture using the 48" box blade I picked up used. Makes you a little nervous as you are working it because it gets worse before it gets better.
Would have liked to keep going but I ran out of daylight then it snowed. The strangest part is it feels like you are just dragging gravel back and forth. In reality you are digging up the old gravel.
/ Is a GC1705 box blade combo going to work? #16
Not bad for 1st time use and only manual adjustment.View attachment 579160
Looks good!
2011 CATERPILLAR CP56 PADFOOT ROLLER (A60429)
2011 CATERPILLAR...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
2018 JOHN DEERE 333G SKID STEER (A60429)
2018 JOHN DEERE...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A61306)
2023 Takeuchi TL6R...
2019 Ford Transit 250 Cargo Van (A59230)
2019 Ford Transit...
WHITE PINE TONGUE & GROOVE (A60432)
WHITE PINE TONGUE...
