Trailer mover vs rear hitch on Ventrac
   / Trailer mover vs rear hitch on Ventrac #1
ChiefBodie
Ventrac 4500Y
The salesman wants me to buy a trailer mover. I need to put in/pull out a fishing boat from a dock. Lightweight boat on trailer.
The trailer mover (front) is expensive. There is a receiver hitch in the back. Is that receiver strong enough to pull a boat trailer and 14ft aluminum boat up a paved ramp? Seems it would be much cheaper to do it this way vs a trailer mover.
   / Trailer mover vs rear hitch on Ventrac #2
the trailer mover lets you do it from the seat, with the jack still down. Take the boat off and park the trailer and move away and never get out of the seat. This very similar to how the trucks do it in the yards, it picks them up off the dolly wheels and drops them in a spot and never crank the the dolly wheels up...... jim
OK. Seems expensive for a little convenience. If I had a yard full of trailers it might be appealing.
   / Trailer mover vs rear hitch on Ventrac #4
I have too much stuff lying around and too much Steiner stuff. The last thing I would want is a little used attachment cluttering up the place, especially one that is not critical to the task at hand. I pull, a harrow, a grass collection sweeper and roller behind my Steiner, without issue and a BIG advantage is, I can leave what's on the front there.
I built a 2" receiver for the back of my Steiner.
I use my forks all the time on my small wheel loader to move around trailers. If you have rolling terrain, it is extremely easy to bend the trailer tongue jack if you leave it down.
   / Trailer mover vs rear hitch on Ventrac #5
I just made one, not as long but it sure beats all the cranking...... jim
   / Trailer mover vs rear hitch on Ventrac #6
If this is a chore you do often, then it could be a good idea; such as working at a marina. If it is an attachment that is going to rust away in the weeds .... It is WAY easier with the trailer in front. I back, from the back of the tractor, my trailers on occasion with the Ventrac, about 2,700 pounds max on up to 20 degrees and that is pushing the traction limits given the weight of the Ventrac. Sure makes my neck ache if I have to do much of it. But, do not do enough to make or buy the front attachment.
prs
   / Trailer mover vs rear hitch on Ventrac #7
prs
You are right but what I made is a trailer ball attachment and a ripper and a little boom for lifting things. All made with scrap angle and tubing all fit the same mount, and it is light and pick it up and put it on..... jim
   / Trailer mover vs rear hitch on Ventrac #8
I had a roller push over my Steiner on a hillside. I was not using duals which probably would have prevented the roll over. The Steiner/Ventrac are a good sturdy machine, but not that heavy, and will easily pull something bigger than the tractor.
   / Trailer mover vs rear hitch on Ventrac #9
I would guess you lost it going down hill right? and started to slide in the grass?.... jim
   / Trailer mover vs rear hitch on Ventrac #10
EXACTLY. I have pulled this roller, which maybe is a little large (filled with stone) on a number of occasions. I was rolling seed, not paying enough attention to the dynamics, and maybe in a little too much of a hurry. Basically, I attempted a turn without having come to a dead crawl.
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
