Bobcat T770 doesn't seem to preheat
/ Bobcat T770 doesn't seem to preheat #1
Spike-MI
Chelsea, Michigan
JD4720, JD7920, JD6420
Hi all, I have a "new to me" 2015 T770 T4 with 2800-ish hours on it. It has the deluxe panel on it. We are hovering around 30degrees here in MI right now and when I turn the key to the on position it says "wait to start" for maybe a second and then goes away. All my other Bobcat machines (2018 E50, 2007 T300, MT55, etc) are all requiring 5-10 seconds of preheat in the same conditions. What I have noticed is that if I leave the heater fan on and turn the key on, the fan does not kick on for 5-10 seconds. Are these units set up to kill all the auxiliary power draws during preheat? If so, maybe the preheater is working but not showing on the screen? Any ideas?
Thanks
/ Bobcat T770 doesn't seem to preheat #2
Thanks
This unit didn't come from Texas did it? Seen one or two of those flood units making there way to the NE. Could be a temp sensor issue. What is the displayed temp at start up? Post the sn#?:confused3:
/ Bobcat T770 doesn't seem to preheat #3
Easiest way to check is w/ a volt meter..
Have someone turn the key on while some checks to see if your getting power "AT" the gp rail.
& "a second" isn't enough time to heat-up anything..
/ Bobcat T770 doesn't seem to preheat #4
The glow plug wait symbol and countdown timer is on the left side cab panel, the one with the fuel and temp guages.
The right side panel doesn’t display a wait symbol.
UNUSED RAYTREE RMBG72-72" HYD ROOT GRAPPLE (A60432)
UNUSED RAYTREE...
UNUSED FUTURE P45-56" MINI HYD BREAKER HAMMER (A60432)
UNUSED FUTURE...
UNUSED KJ K0720-7'X20' METAL FARM DRIVEWAY GATE (A60432)
UNUSED KJ...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
1986 Ford LNT9000 Dump Truck (A61306)
1986 Ford LNT9000...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
