Bobcat T770 doesn't seem to preheat
   / Bobcat T770 doesn't seem to preheat #1
Spike-MI
Chelsea, Michigan
JD4720, JD7920, JD6420
Hi all, I have a "new to me" 2015 T770 T4 with 2800-ish hours on it. It has the deluxe panel on it. We are hovering around 30degrees here in MI right now and when I turn the key to the on position it says "wait to start" for maybe a second and then goes away. All my other Bobcat machines (2018 E50, 2007 T300, MT55, etc) are all requiring 5-10 seconds of preheat in the same conditions. What I have noticed is that if I leave the heater fan on and turn the key on, the fan does not kick on for 5-10 seconds. Are these units set up to kill all the auxiliary power draws during preheat? If so, maybe the preheater is working but not showing on the screen? Any ideas?
Thanks
   / Bobcat T770 doesn't seem to preheat #2
Thanks
This unit didn't come from Texas did it? Seen one or two of those flood units making there way to the NE. Could be a temp sensor issue. What is the displayed temp at start up? Post the sn#?:confused3:
   / Bobcat T770 doesn't seem to preheat #3
Easiest way to check is w/ a volt meter..
Have someone turn the key on while some checks to see if your getting power "AT" the gp rail.
& "a second" isn't enough time to heat-up anything..
   / Bobcat T770 doesn't seem to preheat #4
The glow plug wait symbol and countdown timer is on the left side cab panel, the one with the fuel and temp guages.
The right side panel doesn’t display a wait symbol.
9202 (A50322)
9202 (A50322)
2005 International 4300 Telsta Telescopic Bucket Truck (A55973)
2005 International...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
10' CONTAINER (A52706)
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
2018 ASV RT30 Posi-Track High Flow Compact Track Loader Skid Steer (A55851)
2018 ASV RT30...
