Value of "rough looking" but "solid working" Kubota L345 4wd with loader
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #1
travelrider73
Member
Palmetto, FL
Kubota B7100HST
I'm looking at a listing for a Kubota L345 4wd with loader.
Owner is asking $5000 "firm".
It's kinda rough looking, tach and hour meter don't work and so owner claims to know nothing about how many hours.
Hood and grill are missing.
I'm told the hydraulics, PTO, and Engine are in good operating condition.
Would you pay $5k for that tractor in that condition?
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #2
Re: Value of "rough looking" but "solid working" Kubota L345 4wd with loader
In one word NO!
How do YOU know it's a "solid working" tractor? Because he told you so??
Didn't you already check it out for yourself??
SR
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #3
Is the owner willing to demo the tractor for you? Make sure the PTO and hydraulics work, have him do a cold start for you, check the fluids and tires etc.
The only reason I say maybe is because that’s a lot of tractor for $5K. Japanese Diesel, 4wd, loader tractors of that size usually bring $10-15K. If everything works and you can get it for $5K it might be worth it. People buy old Fords and John Deere’s with busted hour meters all the time, you just need to be more diligent about inspecting the machine yourself.
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #4
It’s looks pretty rough to me, like it was used hard. The hood is missing probably because it was tore up. I’d also pass.
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #5
I also would pass . When ever I make a purchase like that I always ask myself if I had to sell it tommorow could I get most of my $ back . I rather use that 5K towards purchase of a new one , if you could swing that . I'am a huge Kubota fan but I think that tractor will end up being a money pit .
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #6
No. It is high priced at half that.
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #7
Compact tractors of that size, age and condition do not usually bring $10-15K. A busted hour meter is the least of my concerns.
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #8
Absolutely NOT !!!
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #9
I don't know your situation. If $5K towards a rough tractor that runs is all you can put into it, and you're looking for either light work, or a short term project, then "maybe". How rough a shape would you be in if it died tomorrow and needed a full rebuild (aka, your $5K is gone)? Obviously check it out in person as carefully as you can. I would personally go a different direction and like Bull said, put that money down towards a new one, plus possibly trading in your current one against it as well.
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #10
That's an interesting price point. I doubt I'd go 5K, but that led me to consider just what would cause me to look at that tractor seriously. There are some real positives about these older tractors. In the first place, that's an older USA model from back when Kubota was getting going in this county.... Meaning that Kubota dealers can probably get normal maintenance parts, gaskets, and seals for it, and that aftermarket and used parts places are likely to have used sheetmetal pieces.
And there are some other things that old Kubota has in it's favor. Being an older type, it is very simple in construction. Tractors from that era were designed to be owner maintained - even owner-diagnosed & repaired if they needed it. That makes it particularly appealing to a guy who has some basic mechanical skills. Even more so for the kind of guy who actually enjoys a little mechanical work along with working in the dirt.
And the L345 does have an impressive number of things that are really important. For example it was powerful for its size. It has an appropriately rugged loader, power steering, a reasonable number of gears, Dry clutch and wet brakes, an engine that is large enough to be under stressed, and is generally known to be a reliable machine. I can well believe that the hydraulics, engine, and PTO are in reasonable operating condition - and it is simple enough so that if they work well now they would likely work the same for years to come. Although I would want to test that for myself.
And if I could get the price down a bit I could probably pick up new hoses, oil, filters, a battery....and maybe even some sheetmetal which would quickly turn that tractor from something questionably worth 5K into something definitely worth that much or more.
All of this is dependent on your mechanical skills and your comfort in evaluating second hand machines. I wish I was local and we'd go looking at it together. That's kind of look may be all you need to pick up a good old machine - or it might be a junker. All depends on you and your experience with mechanical things as much as anything. There are good old machines out there, but not many. People like me tend to snap them up.
Not many machines in the 4 to 5,000 dollar range are going to be both powerful, be a desireable make and model, and also be in good cosmetic shape. All I'm saying is that for a certain type of tractor buyer, this is worth looking at.
rScotty
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #11
It’s pretty rough but I think if it’s in mechanically good condition it’s worth it. I’d take that over an 8n Ford any day.
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #12
My opinion is
If the appearance of the tractor doesn’t turn you off
If you have a mechanic check it out in advance
If this is all your budget allows
Then this is probably worth the price,
But, if you pay the asking price, and decide to spend a bunch of money prettying up, then you may end up with a more expensive investment than is prudent for that particular tractor. If it was any other make than Kubota, I personally wouldn’t even give it any real consideration.
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #13
I think it would look a whole lot better with a can of paint and a spray gun. $5k isn’t going to buy a very nice tractor with a loader.
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #14
NO!!!!!
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #15
So other than the fact the paint is severely faded and the hood appears to be gone does anyone have any solid reason for knocking this tractor. It deserve a closer look than the one picture we have IMO.
My opinion is
Thanks everyone for the replies. I'm quoting this comment from rgr33 because your comment has me thinking... Your point about me wanting to make it prettier sounds like me, so I'd probably end up wasting a bunch of money on it before all was said and done. If it were a "collectible antique" then maybe that would be worth it to me, and some day it might reach that status, but right now I bet I'd be upside down in that tractor by the time I was finished with it.
What got me interested is what someone else said: It's a powerful tractor for it's size. That's what I want -- the most power I can get shoehorned into the smallest tractor I can buy. I'm not sure where that balance is, but I'm only taking care of 5 acres. The reason I want power is for the PTO implements. I want to be able to run whatever I want, within reason. I have my eye on an 8" chipper, for instance. My Kubota B7100HST is just too small and I find myself not being able to buy toys that I want to buy. I need to step up a notch.
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #17
<snip>
Almost all older Kubota's are "powerful for their size".
Along with the other, comments what are the hydraulics like? Are you comfortable doing your own wrenching? Replacing the hoses and lines yourself could run a grand or more, leaking/bent cylinders can be very expensive. Tires look fair.
Can you get a Used Oil Analysis done?
IF I trusted the seller $5K might be fair.
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #18
Exactly. You don't get much for that kind of money. If it runs and shifts good and the clutch and hydraulics seem strong then it may be worth the money. The tires look decent from what you can tell in the picture. Those old Kubotas were simple and tough. For reference I sold a rough similar vintage Kubota L275 15 months ago for $2700. The loader arms were broken halfway through, the 3pth arms needed replacing, but it still ran like a top. I started out at $3800 and slowly dropped the price. As someone suggested have a diesel mechanic look at it. If you don't want to pay that much wait a month and he may come down.
   / Value of "rough looking" but "solid working" Kubota L345 4wd with loader #19
Hydraulic hoses are pretty cheap and they’re likely junk unless they’ve already been replaced. Gland seals aren’t very expensive either. Rust on the chrome plating on the cylinders would be a bigger turnoff. And as mentioned the tires look good. I just paid $1100 for 2 back tires. If this tractor engine is good, the hydraulics are good, clutch is good and otherwise operates properly it’s worth the price.
Well, no point to this exercise anymore. He marked the listing sold 24 hours after posting it. I guess it was a good tractor -- or the right person came along already.
Tank Only (A59076)
Tank Only (A59076)
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
