Small Diesel Engines - Natural Aspiration vs Turbo Charged?
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #81
When we transport equipment, we also cover windows facing forward. We have had a good bit of damage there. As far as a rock getting to the turbo, I never hear of it. However, some of our older techs tell us stories of turbos going out after hauling in the past. And if the exhaust point forward, covers also stop the rain.
So covering the exhaust may or may not be required when hauling to keep the turbo fan in good working order if I end up buying a model with a turbo charger. For a 50-60 thousand dollar piece of equipment, I'll stuff a rag in the exhaust pipe, just in case and everyone else can laugh at me..... :)
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #83
On very old engines and young guys that wanted max noise from they're tractor often just put a large pipe straight on to the turbo so in theory this could happen that small stones could enter the turbo, but on all normal designed equipment you have a muffler after the turbo and not just a large pipe.
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #84
In order for vehicle motion to sauté the compressor to rotate, both the intake and exhaust valves would have to be open at the same time on at least one cylinder.
Diesel camshaft design typically has very little valve overlap so the possibility of air flowing from the open exhaust pipe, through the after treatment system, muffler, turbine, exhaust valve, intake valve, and air cleaner, or the other way around is pretty remote.
Sounds like an urban myth.
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #88
You never heard tell of debris making it’s Way down the stack and jam into the power turbine side .
I repeat, NO
Been operating, hauling, or working around turbo diesel equipment nearly every day for several decades and never heard of it.
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #89
I have found bugs inside the carburetor on old engines. I don't know how. Things do get inside turbos and every other part of tractors. My boss has been in the heavy equipment business for over 50 years and he tells all the drivers to cover exhaust if it faces forward. Most of today's large equipment has exhaust that goes up, not forward. I would not worry about my turbo due to the muffler and filter.
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #90
My two non-muffler-diesel-turbo trucks have exhausts that curve down and then up. Debris would collect at the bottom of the curve and blow out when the engine is running. I cap them to keep rainwater out, but debris getting to the turbo has never been a problem.
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #91
Question #1 - Does turbo charging decrease the service life of the engine?
The "specific power" (HP per displacement volume, HP/Liter) is the generally accepted measure for an engine's life expectancy. The lower this figure, the longer the engine will last. A racing car may have 600HP/L and last a few 100 hours. A passenger car around 100HP/L and last 2,000 hours. Tractors have much lower specific power than cars, around 20HP/L. On one hand for a flatter torque curve, on the other hand for a longer service life of around 10,000 hours.
A turbo charger can be designed solely to improve fuel efficiency, in this case specific power remains the same and engine life is not affected.
Or it can be designed solely to maintain power at high altitude, in this case engine life is not affected either.
Or it can be designed to improve power, specific power is increased, and anything else remaining the same, engine life is decreased accordingly.
In practice, a turbo is designed to do a mix of everything above. Depending on which features are emphasized most, there will be more or less shortening of life expectancy. In the case of compact tractors, engine life is a non-issue, as the engine is designed to outlive the rest of the tractor several times over.
Question #2 - Which engine (of the same HP) gets better fuel efficiency?
The turbo Diesel engine will always be more efficient. How much depends on engine size.
On a very large engine (like a ship Diesel engine) a turbo can reduce fuel consumption by 70%. Such turbos are the size of a jet engine, and one single engine piston can have the diameter of a tractor wheel. On a diesel locomotive, savings may be 50%.
The smaller the diesel engine, the smaller the fuel savings. On a small car, savings may be in the order of 20%.
Question #3 - Are there any significant differences in engine maintenance requirements between the two types?
The turbo generally requires a higher specification engine oil.
Question #4 - Are there any significant differences on how well the DPF functions perform between the two types
Don't know the answer to that.
Thanks in Advance :)
[/QUOTE]
I agree with Cba,
Question 2; However, turbo chargers in theory and on paper are more efficient. In the real world they CAN be much less fuel efficient. All depends on the engine, rated rpms, and staying out of the boost. These turbo charged cars running around DRINK way more fuel then the rated mpg when you stay in the boost and zip and get around town. Tractor and diesels CAN also follow suite.
Question number 4 : no difference in my experience.
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #92
[/QUOTE] I agree with Cba,
Question number 4 : no difference in my experience.[/QUOTE]
Absolutely true, on paper they are more efficient, but in real life they suck so much more gas than you can imagine. There are two reasons for having a turbo:
1) For the "Occasional" need of additional hp when a bigger engine doesn't make economic sense, for the buyer
2) To gain additional hp without having to go to the expense of having to design/manufacture a new bigger engine for the manufacturer.
Everything else is puffery.
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #94
Remember that "efficiency" has nothing to do with fuel mileage. Efficiency is output per unit fuel consumed. There are way to many variables to use fuel mileage as a measure of efficiency.
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #95
Very true Trillium and adventure Bob :drink:
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #96
My :2cents:
On a diesel tractor that would be running at a constant engine speed, I do believe a turbo would increase the engine efficiency. I do believe it would allow less valve over lap between intake and exhaust strokes, due to the turbo helping to improve engine exhaust scavenging.
Since a turbo increases intake air pressure an engine's compression ratio needs to be dropped. On a diesel this can make engines with a turbo a little more problematic for cold starting.
A turbo's bearing is actually a film of oil and that oil get real hot when it goes through the turbo, so most turbo charged diesel will have an oil cooler. They also produce a poop load of heat under the hood. So, I think a turbo charged engine requires more maintenance due to the heat it generates and the complexities that it adds.
I don't think you can have an engine with a DPF with out a turbo. You need the turbo to spool up to increase the air going into the CAT, so as to burn off the soot. I could be wrong but that is my understanding.
If I can get away with it I would take a naturally aspirated engine over turbo charged. I would avoid a computer controlled engine like the plague. I work with the stuff all day long. I love the computer controlled stuff, great money maker. A laptop is a lot easier to carry around than say pulling a set of heads. I wouldn't own one on my life. I lied we have one. It is an older IH where the software is free!
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #97
You can have a DPF without a turbo. None of the Kubota economy L3s or my L4060 have a turbo & they have DPFs. Quite a few JDs & others are similar.
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #98
Ah, wonder how they are doing that? learned something new. On the truck engines when it goes into a parked regen, it will close the waste gate spool up the turbo and that CAT gets red hot. I have always thought the regen times(parked) that people were complaining about were rather long. I wonder if not having a turbo would make the regen on the DPF longer?
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #99
They inject extra fuel that ends up getting burned in the DPF.
A catalytic converter causes unburned fuel to catalyze into exhaust products so hydrocarbons dont spew out the exhaust pipe. A DPF (Diesel Particulate Filter) is a filter. It's designed to catch the black soot that comes out of a diesel engine, not cause any chemical reaction like a catalytic converter. Like any filter, DPFs plug up as a byproduct of them doing their job. The regens get them really hot to burn off the accumulated soot. 2 entirely different processes. Diesels typically dont have catalytic converters because they would just plug up from the soot.
/ Small Diesel Engines - Natural Aspiration vs Turbo Charged? #100
This is my turbo, overhaul it with new bearings and seals, parts for 25$, it's very simple to fix, the bearings isn't super tight or that high precision, the important is end play. 629695037.jpeg1734041595.jpeg
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
(4) UNUSED FORERUNNER 12-16.5 SKID STEER TIRES (A60430)
(4) UNUSED...
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
