Antonio Carraro 3800 HST Tigretrac Compact Tractor
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #11
Hi, i recently bought a carraro 3800 hst....i changed the filters and oils but tractor is very very slow and is whining a little from transmision..When i fully press the direction lever it takes 5 seconds to start moving and have...at 3000 rpm and lever at rabbit ..it catches 8 km/h..any idea what to check?
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #12
G'day tonuadrian.
When you replaced the hydraulic fluid 1) did you do it on a level surface and 2) did you check the level of hydraulic fluid the next morning whilst the tractor was 'cold'? (again, on a level surface)
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #13
1)yes 2)yes
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #14
Any foam visible in the hydraulic reservoir?
What type of hydraulic fluid did you use?
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #15
in the rear part, i used 10w30 ambra multi g
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #16
So, the tractor was operating correct before the hydraulic fluid/filter change. You've correctly drained and refilled the hydraulic fluid.
The only thing different, in the process of elimination, is the new filter. Is it the correct filter? Is it seated or 'oriented' correctly (if that is required). If so, it could be blocking/slowing the return of hydraulic fluid to the reservoir = reduced fluid available to run the hydraulic system.
A call to a/your Dealership is in order to answer the filter questions (filter part number/filter seating/orientation).
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #17
I'm thinking it could have some air trapped in the system...
SR
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #18
I don't know if that machine is like my 4400HST or not but on my machine there are 2 reservoirs. One for hydralulic lift (3PT and remotes) and one for transmission. Could you have changed the 'wrong' one?
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
CAT 973 (A47384)
CAT 973 (A47384)
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
