Antonio Carraro 3800 HST Tigretrac Compact Tractor
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #11
Hi, i recently bought a carraro 3800 hst....i changed the filters and oils but tractor is very very slow and is whining a little from transmision..When i fully press the direction lever it takes 5 seconds to start moving and have...at 3000 rpm and lever at rabbit ..it catches 8 km/h..any idea what to check?
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #12
G'day tonuadrian.
When you replaced the hydraulic fluid 1) did you do it on a level surface and 2) did you check the level of hydraulic fluid the next morning whilst the tractor was 'cold'? (again, on a level surface)
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #13
1)yes 2)yes
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #14
Any foam visible in the hydraulic reservoir?
What type of hydraulic fluid did you use?
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #15
in the rear part, i used 10w30 ambra multi g
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #16
So, the tractor was operating correct before the hydraulic fluid/filter change. You've correctly drained and refilled the hydraulic fluid.
The only thing different, in the process of elimination, is the new filter. Is it the correct filter? Is it seated or 'oriented' correctly (if that is required). If so, it could be blocking/slowing the return of hydraulic fluid to the reservoir = reduced fluid available to run the hydraulic system.
A call to a/your Dealership is in order to answer the filter questions (filter part number/filter seating/orientation).
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #17
I'm thinking it could have some air trapped in the system...
SR
   / Antonio Carraro 3800 HST Tigretrac Compact Tractor #18
I don't know if that machine is like my 4400HST or not but on my machine there are 2 reservoirs. One for hydralulic lift (3PT and remotes) and one for transmission. Could you have changed the 'wrong' one?
2018 JOHN DEERE 160G LC EXCAVATOR (A51246)
2018 JOHN DEERE...
2017 JACTO ARBUS-1500 DIAM LOT NUMBER 66 (A53084)
2017 JACTO...
Electric Concrete Mixer (A51573)
Electric Concrete...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
53ft refer trailer (A51694)
53ft refer trailer...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A52577)
2016 PETERBILT 579...
