Kubota L34 Buying Advice
   / Kubota L34 Buying Advice
Thank you all for the great advice and the laughs! Paperwork was all approved today, trailer reserved, tie downs bought. We'll pick it up on Friday and will post some better pics.
   / Kubota L34 Buying Advice #22
Enjoy the new toy!!!
Hi all. Brought her home yesterday. Here are a couple of pics that I took this morning. Have started my list of things that I want to do such as add quick-tach plate to the loader and rear hydraulics, as well as a few implements such as pallet forks, 3-point boom pole, and eventually a grapple. Looking forward to learning from y'all.
   / Kubota L34 Buying Advice #24
View attachment 580218 View attachment 580219
Check the 3-pt with a load. Upon slow lift some of these studder and jump a bit. I've learned to work with mine but "feathering" an implement is difficult.
Other than that I very much like my Grand L3130. It has all of the power and traction I need with R-4 tires.
   / Kubota L34 Buying Advice #25
Hi all. Brought her home yesterday. Here are a couple of pics that I took this morning. Have started my list of implements such as pallet forks, 3-point boom pole, and eventually a grapple.
For many tractor tasks bucket hooks would serve about the same as a Three Point Hitch Boom Pole with the advantage that bucket hooks are always on the tractor. Photo #1. Field Cultivator (load) shipping weight ~~300 pounds. Cultipacker counterbalance 600 pounds.
You can LIFT to your FEL capacity.
But you should PULL prudently, changing load to rear/center or rear cross-drawbar before much force is applied, or you may separate FEL from tractor.
LINK: Ken's Bolt on Grab Hooks <<Kubota Hooks>>
Your L3430 is a two increment predecessor model to my L3560. You will need Three Point Hitch counterbalance of at least 600 pounds, assuming loaded rear tires, for max FEL lifts.
I have air in my rear tires. For max FEL lifts I attach my 1,000 pound Disc Harrow. Since it extends w-a-y back, leverage increases its utility as counterbalance, at the price of maneuverability. Photos #2 + #3 from yesterday. ROPS folded because I was working under tree branches.
Saturated Oak trunk weighed perhaps 1,200 pounds.
For skidding logs a Boom Pole is not the best implement. The load is too far back, too high and the pole is subject to a transitory stress flexing. Safer a rear cross-drawbar with a "hanging tree" to facilitate trunk elevation. Photo #4.
LINK: https://www.tractorbynet.com/forums...actor-three-point-hitch-cross.html?highlight=
   / Kubota L34 Buying Advice #26
Agreed on the boom pole usage!
I have had one sitting in the barn for 30+ years.
NEVER use it!
Great info. Thanks guys! You may have just saved me a few hundred bucks and helped me work better.
Tires (A50322)
Tires (A50322)
1964 Mercedes (A51694)
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
KUBOTA L4600 TRACTOR (A51247)
KUBOTA L4600...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
2014 Ram 4500 Chassis Versalift Bucket Truck (A52377)
2014 Ram 4500...
