I am in the process of purchasing 40 acres of mountainous terrain in NE Washington State. It has a roughly 1 mile access road I will be responsible for. It is steep and windy, over 25% grade in many areas. The road needs a bit of work, but appears well built, plenty of water bars, a culvert or two, nice stone, etc... The property is steep as well, about 10 acres are developable, but still sloped. The property has several leveled buildings sites and a cabin. Planning to use the cabin for a couple years then build a house.
Previous tractor experience is limited to a 25 hp Kubota, mainly clearing snow, but it's been a while.
Its primary task will be taking care of the road. I'd like to add some culverts, ditches, and wooden barriers (plenty of wood around!) on a few of the sharper turns. Ongoing maintenance will have to be addressed as well. I will have to clear it of snow and am pretty much set on a front mounted blower for safety. Planning to prepare some areas for planting once things are settled. Would like to fence a portion of the property as well. It will also pull some duty helping me thin out the trees.
What I'm curious about, and unsure if I should expect any tractor to accomplish this, is cutting trails on my property. I understand a tractor is not a dozer, but would like the ability to cut trails/narrow roads. The soil is soft, decomposed granite that should dig quite well, but occasionally basketball size rocks are present.
What I'm thinking:
Branson 5220h
Box blade
Front mounted snow blower (possible with this tractor?)
Backhoe
FEL
LS, MF, JD, Mahindra and Kubota dealers also nearby, but not seeing a HST option on the LS tractors, generally not considering Kubota or JD due to cost and lower weight. The only plus I see on a comparable MF is that the hydraulic pump has an additional 2 GPM or so. Unfamiliar with Mahindra. I like the added weight of the Branson given the slope of the property and I hear they may be easier to work on than others. Looking for bang for the buck while not sacrificing quality. The Branson dealer has been around a while and seems stable.
Any input is appreciated. Am I thinking too big? Certain options I should consider, such as weights given the slope? Think it could be used to cut trails with any efficiency? Additional attachments?
Thanks in advance!
