JD 6125r exhaust issue - ECU 1209.07
   / JD 6125r exhaust issue - ECU 1209.07 #1
svenlylethor
UT
JD 5420, 6430, & 6125R
I keep getting an exhaust pressure sensor fault on my 6125r. This started about a year ago. My dad would excessively idle the tractor and the exhaust filter would get dirty. I cleaned it a few times over the next months but now it's no longer self cleaning and won't let me manually run the exhaust cleaner. Now I'm getting the exhaust pressure sensor fault a bunch and I need to do something about this.
Has anyone dealt with this before? Is this something I can fix myself or will I have to take it to the dealer?
Thanks in advance for your help
   / JD 6125r exhaust issue - ECU 1209.07 #2
I think you might need a dealer to assist you.
There is a mechanic that has a channel on you tube and he works on a lot of 6 series Deere’s.
It might be worth trying to ask him, I know he reads and responds to a fair number of questions thru the comments sections.
western truck and tractor repair
- YouTube
   / JD 6125r exhaust issue - ECU 1209.07 #3
The R is a pretty new series, right? Any chance that it's still under warranty?
   / JD 6125r exhaust issue - ECU 1209.07 #4
Do you know the code #? I work on construction equipment but may be Able to help with after treatment what engine model is it?
   / JD 6125r exhaust issue - ECU 1209.07 #5
Idling is the killer #1 for a DPF filter. If your parked REGENs won't change the situation anymore, it's likely the dealer has to take the system apart and the filter has to be cleaned of it's ashes which were produced in the REGEN cycles. It's like cleaning the ash tray in your stove.
The cleaning is done in a machine, that can also measure the overall condition of the filter. It might run multiple cleaning cycles while in there. It's also called " baking the filter".
The ECM may have to be reset by the dealer to indicate a cleaned filter to the ECM.
These are procedures that I gathered from truck engines but might as well apply to Offroad Equipment.
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2016 FORD TRANSIT 350 CARGO (A59575)
2016 FORD TRANSIT...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
