Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,304
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
Here's an easy project for a rainy shop day.
1) with an angle grinder cutoff wheel, cut the corners off the hook, so it drops thru slots easier.
2) weld up the crotch of the triangle so you can stuff the strap thru the triangle and use it as a slip-knot. Otherwise the strap gets wedged into that crotch and you can't get it out.
There's plenty of time to weld it and quench before the heat arrives at the nylon.
I welded it then sprayed with water.
