LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 12,458
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Before you start set up a bench with your flywheel sitting on it and blocks the proper height for your ring gear.
You will have better results chilling the flywheel in the freezer or using some dry ice and heating the ring gear in the oven.
It will work much better using both. It is easy to go on to far on many flywheels.
Good luck
Good luck
