Log splitter
   / Log splitter #21
I hand split until my last 50"s...about 10 years ago. My splitter is only 15 tons but it has never let me down. I wish it was faster and I wish the wedge was fixed so the ram could push the splits off the table. I mostly split oak, birch, maple, ash, with a bit of beech. popple, and basswood. Nothing difficult to split. It has split rounds up to 24" in diameter and those came from a tree in had to remove as it was dying and close to the house. Most of my wood is 16" or less.
I use either a boom crane or tractor to lift the large rounds into place over the splitter. No point trading one injury for another.
Like others, I wish I had invested in a good splitter long ago. Beating yourself up is not worth it and there will come a time when hand splitting becomes extremely difficult....the old saying pay me now or pay me later.
Good luck with your new splitter.
   / Log splitter #22
I recently picked up an old splitter ("27 ton" with an allegedly 6hp Briggs engine, I have my doubts about both numbers).
It's not really fast, but a lot of my wood doesn't split easily (scrub oak has a lot of twists and turns to the grain) and this makes it possible.
I really came to appreciate this splitter's ability to go vertical when it came time to split up an old oak tree which I had to take out overhanging the house; at the base the rounds were ovals about 24x30". The splitter wouldn't go through the rounds in half at once, I took chunks off the sides here and there. But with the vertical orientation, I slid rounds down the hill (on an old metal round sled) to where I had the splitter set up, and scooched them around till I had them on the base - no major lifts.
For most of my splitting the horizontal orientation is great, but for the really big stuff, I'm glad to have a vertical option.
   / Log splitter #23
Some of that size round WILL crack all the way across with mine. Others I have to section like you mentioned.
   / Log splitter #24
Yes - for God's sake Bunyip - you may be an old and mythical animal - but be careful. I had a 28 ton hydraulic splitter - and learned in a real big hurry - watch out for the big old tough knotty chunks. When encountering a big old tough knotty chunk - my spitter "shifted down" to a slower but much more powerful mode. It was away possible that the chunk would split most violently and I could easily be hit by a half split. The half chunks would come off the splitter with extreme momentum, speed and force.
And right at the family jewels - ask me how I know. Last week I even had one that went over my right shoulder.
I love to split wood manually and only use the splitter when I was getting too far behind on the 'to be split pile'. Then this year my main customer upped his order from 3 cord to 6 which really ate into my 'ready to sell' stuff. Been out 3-4 hours a day up to the weather got too miserable a few days ago on the splitter. What I don't like about using it is the huge pile of splits it spits out that then have to be stacked. Manually I stack as i go. Stacking is one thing I don't really enjoy in the 'wooding' process.
   / Log splitter #25
I bought one of those $300 electric splitters and the Wife loves it. Quiet and no engine stink. She thoroughly enjoys splitting wood.
I've seen them in operation and am amazed at how well they work!
   / Log splitter #26
I hand split 6 cords a year til about 60 years old and finally got a splitter, an electric splitter.
20 ton, 120/220 volt motor, always run in 220, horizontal/vertical, towable, quiet and odor/pollution free.
I yard my firewood logs behind the workshop so 220 V is readily available.
Splits most anything I can move to it barring big crotches and suchlike
I must admit though, that the factory build was undersized and I consequently have rebuilt the entire rig over the years as one piece or another broke.
Still worth the quiet and green running
   / Log splitter #27
No need to brag about one of the family jewels being flung over your right shoulder...:thumbsup:
   / Log splitter #28
The "crack" of the wood splitting and the woodsy smell of fresh spruce is heavenly.
   / Log splitter #29
I was recently shopping for a splitter. I didn't want to have to user the splitter in vertical mode for big rounds and didn't want to spend the extra $600 on a hydraulic log lift/table. I put the $600 into a thumb for my backhoe. Now I park the tractor beside a pile of logs, pick a log up and swing it to the other side of the tractor and cut off rounds. Once the pile of logs is a pile of rounds I put the splitter where the logs were and use the hoe to pick up the rounds and place them on the splitter. Thumb is useful for lots more than that, so I felt it was the better buy...
   / Log splitter #30
^^ I could have lifted these into place with the bucket. I could have built a table to catch the split off pieces. But the ground was a whole lot more convenient.
   / Log splitter #31
Once you split wood vertically sitting on a stool, not a chair, you’ll never split horizontally again.
   / Log splitter
I am using the 4 in 1 to get hheavier pieces on the table, redgum is no lightweight and a 12 x 20 piece is a two man lift with a lot of bad language
   / Log splitter #33
Once you get a horizontal splitter with a 4 way in the end you’ll never split wood in the ground again.
   / Log splitter #34
I tried it. Miserable experience, can't get any leverage when trying to rotate a 150 lb chunk, constant up/down to keep pieces within reach of the sstool, in a word, much slower and harder than horizontal...at least for me. I only go verticle to bust big roundss to a size I can lift onto the horizontal position. Most times I will noodle rather than wrestling a big round into position for vertical splitting.
   / Log splitter #35
My best buddy did that sitting on a round but he can dead lift 700 lbs. and bench press 550 lbs. He's a Navy Seal and one **** of a man. He's also half my age but I had to use the tractor to push rounds close enough for him to reach.
He got transferred to the East Coast last June and it about broke my heart.
   / Log splitter #36
It is more or less impossible for most folk to do on a stool unless they vastly outweigh the rounds they're cutting and they have a really good back. Most average folk need their legs under them to do much with anything that weighs the same (or more) than their body weight.
   / Log splitter #37
I try to get big chunks for the fireplace out of my 22 ton unit but then I always have a difficult time starting the fires in the morning. An acquaintance and I were talking splitters and he said he had am electric one he would sell to me for $100 so I took it, even though I told myself I would never have one of this dinky little things. I have it sitting on a bench in my shop and whenever I go out there I split a couple wedges and bring them to the house for starting the fires. It works great for my 2x2s. Love little splitters.
For bending over and lifting to the splitter, forget that. Just roll them on a pallet and lift everything with the tractor plus it works for a table once the first two pieces open up a corner. Tractor and splitter.jpg
   / Log splitter #38
^^ That's about all I can see them for. Making one or two last cracks if you have a piece just a little too big for the stove. I might not mind having on inside near the stove, but I'd never try to use one outside to crack logs initially. At least none of any size.
This is my first year with a hydraulic and so far I haven't had any trouble moosing 24-30" oak rounds into place. Roll em, tip em, crack em, rotate em, crack em, repeat as necessary, tossing the chunks aside. Trying to use the loader to raise them to the table and balance the larger split off chunks seems like it would be a whole lot more tricky.
   / Log splitter #39
I cut everything, including the big ones over a wagon, then I can easily slide them right onto my splitters beam, no heavy lifting for me.
I push everything through my splitters 4-way, it goes pretty fast...
SR
2018 Nissan Rogue SUV (A59231)
2018 Nissan Rogue...
2016 Dodge Grand Caravan SE Plus (A59231)
2016 Dodge Grand...
2015 Chevrolet Cruize Sedan (A59231)
2015 Chevrolet...
Spreader Attachment (A56859)
Spreader...
2011 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A59904)
2011 INTERNATIONAL...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
