caterpillar and case tractors not discussed?
   / caterpillar and case tractors not discussed? #2
I was only aware of Cat making one tractor that’s like 200 hp so that’s a given. I don’t think Case is a serious player in the compact tractor market either. So probably for the same reason you don’t see much discussion about BMW trucks.
   / caterpillar and case tractors not discussed? #3
There is a Case IH group on here. Look under "other manufacturers "
   / caterpillar and case tractors not discussed? #4
You wouldn't know Case sold tractors where I live unless you looked on purpose.
   / caterpillar and case tractors not discussed? #6
Problem solved. Now were are talking about them. :)
   / caterpillar and case tractors not discussed? #8
All CAT wheel and rubber track tractors, are AGCO's painted yellow...
CAT did have a big hand in the design of some of them, but AGCO owns the plant they are built in...
SR
SR
My State, County, and town Governments all use either Caterpillar or Case equipment. it must be for a good reason..
   / caterpillar and case tractors not discussed? #10
Your local government probably got the lowest bid from caterpillar/case companies.Does not necessarily mean it is better equipment.
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A55315)
2022 Brush Wolf...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55315)
Mahindra 4550-4L...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
9000 (A47477)
9000 (A47477)
WACKER NEUSON SM120 STAND ON SKID STEER (A52709)
WACKER NEUSON...
