   / Your last generator Maintenance Run #2,021
Because the 200 dollar generator doesn't hold 5 or more qts of oil...
BTW, I bet you a new pu would shut itself down if it ran out of oil!
SR
   / Your last generator Maintenance Run #2,022
If your truck gets that low because you didn't check it :thumbdown:
Also your truck will turn on a light to tell you, hey I'm out of oil,
that should tell to pull over and shut down SAFELY.
That's better then just shutting down as you pull out to pass in traffic.
   / Your last generator Maintenance Run #2,024
Thumbs down to the dumb dumb that doesn't check the oil in his generator too!!
SR
I admit to being very negligent about checking the oil in my big generac. I've had that model a long time, and after checking the oil a dozen times and it uses absolutely no oil, and changing the oil every two years,
well....maybe check dipstick two or three times a year. Which considering it runs every week is probably not enough but again it never uses any oil. Never say never...……...
   / Your last generator Maintenance Run #2,025
Generator on for real since 11am today. High winds/rain and down trees. Weird weather lately... Double our normal rainfall for the month so far... and an EF-2 tornado nearby! Unheard of.
Imagine it will be tomorrow before power is restored. Had my wife go through the mechanical interlock and gen start exercise today with me... again. Glad I did, she didn't remember how to do it.
Happy Honda power at your end :thumbsup:
I hope that you don't have to deal with heavy wind damage nearby.
Rgds, D.
SR
I wouldn't want to bet a pu (or any other) engine on that....... I know of a late model Ford gasser destroyed by running it out of oil.
I've always viewed OIL idiot lights as more like REPLACE ENGINE NOW idiot lights.
It's a pet peeve of mine...... with all the tech/bells/whistles designed into modern pickups, the only light vehicle production engines that I trust to reliably shut down safely with a low-oil condition is a HEUI diesel.
As all engine management today is computer controlled, and most vehicles come with some type of dashboard info screen, it would be trivial to program a Shutting down in 90 seconds Due To Low Oil warning...... with additional delay or bypassing easily accomplished.
It may be out there, but I don't know of any light-vehicle production engine the does that ^.
Do I manually check oil levels - Yes. Do many people not bother - also Yes.
Design-wise, I find it exceptionally lame that a $200 generator does a better job of protecting itself from low-oil conditions, than a $20k+++ vehicle does.
Some new vehicles have factory-deemed "acceptable" oil-consumption rates that are ridiculous, including some "premium" marques.
Excessive Oil Consumption Isn't Normal - Consumer Reports
"Certain Audi and BMW cars standards state that a quart burned every 600 to 700 miles is reasonable."
All engines should regularly be checked for oil-level. That said, I'd gladly trade most of the bling on new vehicles, for an engine that protects itself better....
I hold no illusions that my demographic shows up on the auto marketers radar....
Rgds, D.
   / Your last generator Maintenance Run #2,028
Ours went out about the same time, cable went out about 3 hours later. Most of the county is out and this is the third outage for me in a week. Generator was full of ethanol free and I have 10 more ethanol free gallons. Hope it makes it.
   / Your last generator Maintenance Run #2,029
Surprisingly, we didn't lose power. All around us, but not here. We lost power 3 times at work. I think last tornado was last year.
Chatted with a buddy in the Fraser Valley late today...... pretty bad windstorms through there too.....
His service truck is stranded at a property he is working at........ tree came down and dropped a 14kv line across the driveway.
Fortunately nobody hurt, but truck is stuck there till the utility crews clear the line.
Here's hoping everybody gets through this mess safely :thumbsup::thumbsup:
Rgds, D.
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
CATERPILLAR H120S HYD HAMMER (A52707)
CATERPILLAR H120S...
SHOP CAGE WITH CONTENTS (A55745)
SHOP CAGE WITH...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
