Are WalMart SuperTech oils worth it?
   / Are WalMart SuperTech oils worth it? #11
I would say that if the SAE requirements on the can meets your engine requirements then you are set to go.
   / Are WalMart SuperTech oils worth it? #13
   / Are WalMart SuperTech oils worth it? #14
Just tried it with conventional 10-30 and there were three: Citgo, Delfin Group USA LLC, and Warren Distribution.
Not sure about others.
That's me! Plant I work in is near Wheeling, WV, with others in Iowa, Texas, and Alabama. I've been there nearly 2 years, great company, I can see myself retiring from there... 20+ years to go!
   / Are WalMart SuperTech oils worth it? #15
if you are asking is the supertech synthetic is as good as Moible one synthetic, Amsoil, rotella T6, etc,.
The answer is no. There is a reason it cost less.
Go to the website bob is the oil guy. Many people will have a VOA performed on oils and post the results.
I can assure you that supertech synthetic won't stand up to the major brand synthetic specs
   / Are WalMart SuperTech oils worth it? #16
Post one up! Because the BITOG thread I posted above showed SuperTech Synthetic to be holding up very well, even with extended drain interval.
   / Are WalMart SuperTech oils worth it? #17
you would need to go to the site and search out the supertech VOA . then search out mobil one VAO
I tried it out several years ago, and with UAO at 4500 miles. The TBN was at 2.
I don't know if you read a a comment there, or read where someone posted UAO spec sheet
I'm willing to bet that supertech synthetic isn't going to have a 12 TBN though.
   / Are WalMart SuperTech oils worth it? #18
Super Tech Full Synthetic SAE 5W30
Not Provided
Metals (ppm)
Iron (Fe) <1 Chromium (Cr) <1 Lead (Pb) <1 Copper (Cu) <1 Tin (Sn) <1 Aluminium (Al) <1 Nickel (Ni) <1 Silver (Ag) <1 Titanium (Ti) <1 Vanadium (V) <1 Contaminants (ppm)
Silicon (Si) 5 Sodium (Na) 5 Potassium (K) <1 Water (%) <0.05 Additives (ppm)
Magnesium (Mg) 483 Calcium (Ca) 1293 Barium (Ba) <1 Phosphorus (P) 753 Zinc (Zn) 826 Molybdenum (Mo) 73 Boron (B) 197 Physical Tests
Viscosity (cSt 100C) 11.0 Viscosity (cSt 40C) 67.0 Physical / Chemical
Base Number (mgKOH/g) 7.7
here's the spec sheet for Amsoil OE oil. not the SS oil
https://www.amsoil.com/lit/databulletins/g1404.pdf
Notice the Amsiol starts with a 10 TBN. While supertech starts with 7.7
Guess it all depends on what you mean by extended drains.
You base them on UAO, or ???
   / Are WalMart SuperTech oils worth it? #19
Is it good? Probably the answer is yes.
Is it as good as the big brand oils? Probably the answer is no.
Is it close enough for many? Probably the answer is yes.
Is it good enough for everyone? Definitely the answer is no.
I am in the last camp.
   / Are WalMart SuperTech oils worth it? #20
Now I would agree with that. Worth what you pay for it. I think so. As long as a person doesn't expect it to be equal to the major manufactures' top of the line oils.
The O.P. merely asked if Walmart's SuperTech oils were worth it, not how it compares with major brand oils. Some people just get carried away trying to make comparisons that weren't asked for. While it may be not as good, is the best really necessary in all cases?
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
1992 VIM TRAILER MFG CRUDE TRAILER (A55745)
1992 VIM TRAILER...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
INDUSTRIAL AIR GAS POWERD AIR COMPRESSOR (A55745)
INDUSTRIAL AIR GAS...
