ym 1500 transmision hydraulic oil
   / ym 1500 transmision hydraulic oil #11
Not 80-90. That is used only in the 4x4 front axle.
What you need is UTF, Universal tractor fluid. Autozone, NAPA, and any farm supply will have it. A later multigrade version is preferable for a cold climate.
   / ym 1500 transmision hydraulic oil #12
Unless you have a particular reason to change the HT/TRAN oil, such as water contamination, (milky) or burned look/odor, or hydraulic problems there is no need to do so as routine maintenance.
   / ym 1500 transmision hydraulic oil #13
I think most manufacturer's recommend changing it around 300 hours.
   / ym 1500 transmision hydraulic oil #14
Most of the older farmers would filter the fluid and reuse if it all looked and smelled normal. No sense buying new when one can filter it to re-use.
Yep, if there isn't an issue, no sense changing it.
   / ym 1500 transmision hydraulic oil #15
As others already posted, does it look contaminated? Milky looking, or burned smell to it? If so then yes I would drain, clean the filter and put new in. JD 303 hydraulic oil, or equivalent will work for your tractor. Any farm store or auto parts store should have this available, and a lot of times you may find it on sale too.
   / ym 1500 transmision hydraulic oil #16
Talk about a zombie thread.
Best to start your own. And I am sure other guys have said already, but DO NOT put 80w90 in there. Use tractor/transmission fluid.
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53472)
2020 Westfield MKX...
Kubota BX2230D (A47384)
Kubota BX2230D...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
Electric Concrete Mixer (A51573)
Electric Concrete...
HARDEE D-3-816 LOT NUMBER 155 (A53084)
HARDEE D-3-816 LOT...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
