ym 1500 transmision hydraulic oil
   / ym 1500 transmision hydraulic oil #11
Not 80-90. That is used only in the 4x4 front axle.
What you need is UTF, Universal tractor fluid. Autozone, NAPA, and any farm supply will have it. A later multigrade version is preferable for a cold climate.
   / ym 1500 transmision hydraulic oil #12
Unless you have a particular reason to change the HT/TRAN oil, such as water contamination, (milky) or burned look/odor, or hydraulic problems there is no need to do so as routine maintenance.
   / ym 1500 transmision hydraulic oil #13
I think most manufacturer's recommend changing it around 300 hours.
   / ym 1500 transmision hydraulic oil #14
Most of the older farmers would filter the fluid and reuse if it all looked and smelled normal. No sense buying new when one can filter it to re-use.
Yep, if there isn't an issue, no sense changing it.
   / ym 1500 transmision hydraulic oil #15
As others already posted, does it look contaminated? Milky looking, or burned smell to it? If so then yes I would drain, clean the filter and put new in. JD 303 hydraulic oil, or equivalent will work for your tractor. Any farm store or auto parts store should have this available, and a lot of times you may find it on sale too.
   / ym 1500 transmision hydraulic oil #16
Talk about a zombie thread.
Best to start your own. And I am sure other guys have said already, but DO NOT put 80w90 in there. Use tractor/transmission fluid.
2018 INTERNATIONAL LT SLEEPER (A52576)
2018 INTERNATIONAL...
JOHN DEERE 8R 340 LOT NUMBER 96 (A53084)
JOHN DEERE 8R 340...
2016 FREIGHTLINER M2 WATER TRUCK (A51247)
2016 FREIGHTLINER...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
