1966 Ford 3000 made in England diesel value
   / 1966 Ford 3000 made in England diesel value #1
RoyKing
Gainesville Florida
M7060HSC/18, RTV-X1100C
Everything works on it does have any collector value?
   / 1966 Ford 3000 made in England diesel value #2
No collector value and no increase or decrease because it is a British built machine.
To give you a better estimate on value we would need a lot more info.
Does the tractor have power steering, which transmission, live pto or not, overall appearance - paint, cleanliness, fenders, hood, grill, etc.
Engine strong, no smoke? Rattles, welds, need repairs, poor repairs done?
Last but not least is condition if the tires. Rear tires plus rims and tubes, mounting can easily cost $1500 to replace.
Location drives values too.
An average 3000 D will start about $2500 for a good runner and can go as high as $5500 for a pristine unit.
   / 1966 Ford 3000 made in England diesel value #3
Ultradog is spot on. Condition, tires, power steering, live pto, location. They have parts availability and are desirable. I prefer older units with wet brakes.
Very good mechanical, good tires, live pto, 8 speed, no power steering, good rubber, needs paint, small dent front cowl 2500 hrs. No leaks or drips, new radiator water pump hoses, rebuilt steering box. Hyd all good, runs good no smoke. So I'd say the $2500 price is ok got shop manual, thanks
   / 1966 Ford 3000 made in England diesel value #5
For what you describe $2500 is a very good price.
Those are great small tractors.
   / 1966 Ford 3000 made in England diesel value #6
A good one goes for quite a bit more than $2500 here. Typical is $4,500 to $6,000 with really nice ones going for more. The only one I've seen for $2,500 was a gas model that was amazingly rough.
I just put rear tires and rims on mine. $1477 for Titan rims with Thia made Cropmasters. Add $400 for US made tires. The short of that is that tire condition is a huge consideration in buying an older tractor.
I know if I fix the dent and paint I get more, but other more important work to do.
HYDRAULIC FLOOR JACK (A53843)
HYDRAULIC FLOOR...
Cattle Gates / Feeder (A53117)
Cattle Gates /...
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
