D170 with failing K46 transmission, now what
   / D170 with failing K46 transmission, now what #11
Is the D170 the cheapest model Deere puts their name on? Just wondering if it is and unfortunately just the reality of it all.
Possibly to have share of the low-price market, and possibly mfg by MTD ??
   / D170 with failing K46 transmission, now what #12
   / D170 with failing K46 transmission, now what #15
Deere makes them, but it's a comparable product to an MTD. I like my Deere equipment but never felt good about them manufacturing low end mowers. I guess they are taking advantage of the brand name to compete in the low end of the market, but those products just aren't very good.
   / D170 with failing K46 transmission, now what #16
If you are using the mower for anything other than mowing a normal, level, lawn, you can expect problems around 200 hours. That's just they way they are built.
Consider the K66 upgrade ... it works great.
   / D170 with failing K46 transmission, now what #17
Or just buy the MTD at half price.
   / D170 with failing K46 transmission, now what #18
Yeah, I personally wouldn't do the upgrade kit that is widely available online. If you sourced the parts and could do it much more affordably it could work out. I had a customer who had the kit done on his L series. It did work real well. 1900 clams seems like a bit much. The same folks will sell you a nice looking front axle for about 400$. Really these 40/ 46 transaxles can become problematic much earlier than they should. Yet the next guy gets 600, 800 hours or better.
   / D170 with failing K46 transmission, now what #19
The fact is there's probably millions of them that work just fine. I think Tuff Torq builds them to a price point and the machining is probably not as tight as it should be. Those that are a little loose probably are the ones that have issues sooner than expected.
   / D170 with failing K46 transmission, now what #20
Hi Roger...what model K66 comes with the kit? AC or R or etc? Does it have diff lock? I'm extremely close to buying the upgrade kit having everything in order on my L120 for this spring.
2005 INTERNATIONAL DURASTAR 4400 24FT BOX TRUCK WITH LIFT AXLE (A56138)
2005 INTERNATIONAL...
405 (A52706)
405 (A52706)
2007 FREIGHTLINER WATER TRUCK (A55745)
2007 FREIGHTLINER...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
AIR COMPRESSOR (A55745)
AIR COMPRESSOR...
