D170 with failing K46 transmission, now what
   / D170 with failing K46 transmission, now what #11
Is the D170 the cheapest model Deere puts their name on? Just wondering if it is and unfortunately just the reality of it all.
Possibly to have share of the low-price market, and possibly mfg by MTD ??
   / D170 with failing K46 transmission, now what #12
   / D170 with failing K46 transmission, now what #15
Deere makes them, but it's a comparable product to an MTD. I like my Deere equipment but never felt good about them manufacturing low end mowers. I guess they are taking advantage of the brand name to compete in the low end of the market, but those products just aren't very good.
   / D170 with failing K46 transmission, now what #16
If you are using the mower for anything other than mowing a normal, level, lawn, you can expect problems around 200 hours. That's just they way they are built.
Consider the K66 upgrade ... it works great.
   / D170 with failing K46 transmission, now what #17
Or just buy the MTD at half price.
   / D170 with failing K46 transmission, now what #18
Yeah, I personally wouldn't do the upgrade kit that is widely available online. If you sourced the parts and could do it much more affordably it could work out. I had a customer who had the kit done on his L series. It did work real well. 1900 clams seems like a bit much. The same folks will sell you a nice looking front axle for about 400$. Really these 40/ 46 transaxles can become problematic much earlier than they should. Yet the next guy gets 600, 800 hours or better.
   / D170 with failing K46 transmission, now what #19
The fact is there's probably millions of them that work just fine. I think Tuff Torq builds them to a price point and the machining is probably not as tight as it should be. Those that are a little loose probably are the ones that have issues sooner than expected.
   / D170 with failing K46 transmission, now what #20
Hi Roger...what model K66 comes with the kit? AC or R or etc? Does it have diff lock? I'm extremely close to buying the upgrade kit having everything in order on my L120 for this spring.
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
GROUND PROTECTION PAD 8X4 15 COUNT (A55745)
GROUND PROTECTION...
Pull-Behind Reel Mower Tractor Attachment (A55851)
Pull-Behind Reel...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2018 CAT 336FL EXCAVTOR (A55745)
2018 CAT 336FL...
2018 John Deere TX (A53317)
2018 John Deere TX...
