Creosote reducing logs in a wood stove
   / Creosote reducing logs in a wood stove #51
Why? I’m in WA and I don’t recall humid days at all.
You are on the dry side, lucky dog. Until summer comes :D
Our 1 day of summer beats all. :laughing:
   / Creosote reducing logs in a wood stove #52
Those people might want to start burning soft wood, you get more snap crackle pop out of soft wood. My son has bee burning mostly cedar labs and buttons from his shingle mill and that snaps crackles. I burn sawmill slabs in my garage, hemlock and pine and that snaps an crackles, hardwood not so much.
The first pic is what the wood looks like when first brought in Oct, sec pic is tonight before I add water :scratchchin:
View attachment 588434 View attachment 588435
Looks like you have to guard against spontaneous combustion, that wood is so dry. :thumbsup:
   / Creosote reducing logs in a wood stove #53
Do they work? I noticed a Dura Flame type log at Wally World that supposedly helps eliminate creosote in stove pipes. Just wondering what your thoughts are regarding them. I burn wood at my hunting cabin. I don't regularly clean the pipes. Are these things helpful?
Google Anti-Creo-Soot ACS. It is a spray & I've used it for several years with good results. It does keep the creosote from becoming like tar. I do clean my chimney yearly.
   / Creosote reducing logs in a wood stove #54
   / Creosote reducing logs in a wood stove #55
   / Creosote reducing logs in a wood stove #56
That why getting rid of ashes is a pay attention job especially hot ashes, last week on local news a house burned down because hot ashes left near combustibles.
   / Creosote reducing logs in a wood stove #57
Good point:thumbsup: When I clean the stove my ashes go in metal pail with metal lid straight outside and are set on concrete. Taking no chances. The are usually semi hot.
   / Creosote reducing logs in a wood stove #58
You spray it on the wood?
Anyone use this product?
Rutland-Products-98-Creosote-Remover
I've used the Rutland crystals, but I bought it from a local hardware store, not Jeff.
Get a roaring flame going & spray it on the flame. It does seem to keep the creosote from becoming like tar.
I use it but I still brush my chimney at least once a year.
From what I'm reading here (and my own practice) if you keep a 'roaring flame' often enough, there will be less need for add-on products.
   / Creosote reducing logs in a wood stove #59
That is absolutely correct. I do get the flames going pretty good when I am here. However not being here
during the day the fire does die down and smoulders. Also my chimney is masonry & is outside the house which is not ideal.
   / Creosote reducing logs in a wood stove #60
A fire burning down doesn't have much, if any, organics left after being burned up.
Does your masonry chimney have aline? If so, it should double-lined, helping insulate. If no liner, not good: Sweep's Library - Unlined Masonry Fireplace Chimneys
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
Unused Delta Crash...
2010 International 4300 TMA Attenuator Truck (A52377)
2010 International...
John Deere 6120E (A50323)
John Deere 6120E...
