Chopping wood help please.....
   / Chopping wood help please.....
Thanks guys for all the insight. For sections of the tree that Y in shape how do you cut them? See attached.
   / Chopping wood help please..... #22
I usually cut the extending pieces off so they’re straight. That appears to be what you have done. That piece isn’t very big or nasty so I’d put it through the splitter as is. Sometimes I cut them in half before splitting. I assume you’re not using a maul. If that was the case I’d leave that piece in the woods. IMG_1120.JPGIMG_1122.JPG
   / Chopping wood help please..... #23
I just split odd shaped stuff like everything else & those go toward top of pile since they screw up stacks.
   / Chopping wood help please..... #24
I try to cut perpendicular to log, and avoid cutting at an angle. Depending on how you split that you may end up with one piece 22" long and another 12". Or you end up trying to make the wood splitter push/split against an angled surface which can get wacky.
At a "Y"/crotch, I try to cut each leg same length and perpendicular so I don't end up with 12" & 22" pieces coming out of the splitter. But how easy this is depends on which end of the tree you started on. If from the branch end you end up like in your picture. If from trunk end you can have even legs.
   / Chopping wood help please..... #25
Yup, hydraulic splitter will make short work of those. Knots and joints can be a bit stringy and may need more than one go to fully separate.
   / Chopping wood help please..... #26
Back when I did use a maul (and thankfully those days are long past), I'd cut it down with the saw to something that would fit in the stove/etc, and call it an "all nighter"
1969 JOHNSON J25 GOOSENECK TRAILER (A51222)
1969 JOHNSON J25...
2013 COACHMEN CATALINA TRAVEL TRAILER (A50854)
2013 COACHMEN...
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
2016 KENWORTH T660 SLEEPER (A50854)
2016 KENWORTH T660...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
