Case Farmall 95 pump or injector troubles.
   / Case Farmall 95 pump or injector troubles. #1
Timm250
Gold Member
Western KY
Kubota M6800 w/1600 hrs., Case Farmall 95 w/800 hrs., Long 2510 w/1100 hrs, Cat 236B2 Skidsteer w/1000 hrs
I have a 2009 Case Farmall 95. It started having problems awhile ago.
It will idle normal & sometimes run normal but after a few minutes it will start surging and blowing white smoke from the exhaust.
If you take it back down to idle it seems fine.
It has a Bosch pump.
Here's a couple videos of it running.
Case Farmall 95 - YouTube
Case Farmall 95 @ idle - YouTube
   / Case Farmall 95 pump or injector troubles. #2
Have you changed your fuel filter lately? That's the first thing I'd be looking at, as they can cause all kinds of problems.
SR
It has a new filter. I also changed all the lines from the tank to the filter. The old ones were so brittle if you moved them they would break.
While I was doing that I drained the tank & checked it. It was clean. No water or trash in the tank.
SR
   / Case Farmall 95 pump or injector troubles. #4
The next thing I'd check is, are you getting any air bubbles at the injection pump, from a possible air leak...
Does your tractor have a "lift" pump, is it weak?
Is there a screen in the back of the injection pump by chance? My dozer has a little brass screen in the back of the injection pump at the inlet, it was partially plugged and limiting fuel, to the pump.
SR
It has a clear inline strainer before the lift pump & you don't see any bubbles in it.
It does have a mechanical lift pump that works off the engine. It has a lever on the bottom of it to prime the filters.
   / Case Farmall 95 pump or injector troubles. #6
My 1st thoughts are a weak lift pump..
   / Case Farmall 95 pump or injector troubles. #8
I also would be checking that lift pump closely...
SR
   / Case Farmall 95 pump or injector troubles. #9
at 25.00 I wouldn't even bother making a pressure tester..
Have a pump coming. It's supposed to be here Thursday.
The tractor started up & ran normal up to 2400 rpm. I used it to check cows & it ran for about 45 minutes before it acted like it ran out of fuel & died.
It started back up & would only idle after that.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
Ideal Applegate 180 gal Water Trough (A50515)
Ideal Applegate...
2011 PJ Tilt Deck Gooseneck Trailer (A50514)
2011 PJ Tilt Deck...
10' Feed Bunk (A50515)
