Case Farmall 95 pump or injector troubles.
   / Case Farmall 95 pump or injector troubles.
   / Case Farmall 95 pump or injector troubles. #12
That's how a weak lift pump would act... Hopefully that will fix it...
My neighbor has a JX95 with a cab... It was acting up, and it ended up being a pinched fuel line under the cab.
SR
I had a pinched line too. I fixed it when I replaced all of the line from the filter to the tank.
   / Case Farmall 95 pump or injector troubles. #14
My CIH dealer took the clear line off, replacing it with blk. fuel line... Some years later, the inner blk. line started dissolving, plugging everything up!
I hope you put on the clear line and NOT gas line?
SR
I put on the black fuel line. It is SAE J30R7 grade. It said it is rated for gas or diesel.
???? Hopefully it won't breakdown.
   / Case Farmall 95 pump or injector troubles. #16
I can't help you there... I know that my neighbors tractor now has the clear back on it...
SR
   / Case Farmall 95 pump or injector troubles. #17
Have u ordered the supply pump?? or at least checked the psi??
Did u unhook the cold start device{CSD}
I ordered the pump. It will be here Thursday. I haven't checked the pressure. I had disconnected the cold start device & it didn't seem to make a difference.
So I got the pump yesterday and put it on this afternoon. Ran a lot better but after about 45 minutes it would still sputter when it gets about 2000 rpm.*
The sputtering is not as bad as before. It will bog down until it almost dies the come back up as soon as you let off the pedal.
   / Case Farmall 95 pump or injector troubles. #20
How about with the fuel cap loose? Maybe it's not breathing and letting air in?
SR
New/Unused Mini Crawler Dump (A57453)
New/Unused Mini...
2016 Morbark Chipper (A55787)
2016 Morbark...
2026 Anvil Trailer (A56859)
2026 Anvil Trailer...
2015 Chevrolet Silverado (A56858)
2015 Chevrolet...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
