Kubota ZD1211 vs John Deere 757
   / Kubota ZD1211 vs John Deere 757 #11
Sorry I left this high and dry. Life got hectic after my last post.
The tall grass I cut was very dry and didn't build up in my deck at all. I noticed the poor quality cut on my 2nd try with the machine so the blades were still "factory" sharp.
I purchased the 92-116 blades but the hole diameter was to small. I called a couple machine shops to try and have the hole enlarged to 1 5/16" but had no luck (they claimed liability reasons). I hope to figure something out this upcoming season.
If you come up with something let me know. I’m in same boat
   / Kubota ZD1211 vs John Deere 757 #12
I have a ZD1011 and had the same issue with not being able to find blades with a hole big enough. I bought one of these and used the drill press to drill the holes, it took some time and a lot of cutting fluid but it got the job done. I used the blades today for the first time, they worked much better than the Kubota blades.
EZARC Carbide Hole Cutter Heavy Duty for Stainless Steel, 15/16 Inch 24mm https://www.amazon.com/dp/B01I416RZS/ref=cm_sw_r_cp_apa_i_XRpwCb9E8KPGF
Interesting. How did you ensure the hole stayed true center with the pilot bit being obviously smaller than the factory hole in the blade?
I tried a HD step bit in a drill press, lots of oil and lots of pressure. All I did was scratch the paint.
   / Kubota ZD1211 vs John Deere 757 #14
I used a vise on my drill press, clamp it all down and nothing can move.
The blades are very hard steel, you have to use a carbide bit.
2008 Chevrolet Impala Sedan (A55758)
2008 Chevrolet...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A55301)
2020 Westfield MKX...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A54757)
UNUSED IRANCH SEMI...
2017 Ford F-150 Pickup Truck (A55788)
2017 Ford F-150...
