What to look for when buying a dozer help us?
   / What to look for when buying a dozer help us? #31
I've owned my JD 350C since about 2002 and it has always served me well without a lot of issues. The biggest thing I did to it besides putting on new tracks two years ago was to have the injector pump rebuilt which cost me about $750 about 10 years ago.
Here's a pic of mine on the dealer's lot when I bought it.
And here's a pic of it with the new tracks:
New and tight tracks is a wonderful feeling. Looks great.
Did you do the tracks yourself?
   / What to look for when buying a dozer help us? #33
Deere 350 were very popular for making back country trails and trail maintenance and I see a lot for small logging plus there were option such as a backhoe... several have told me Deere had a refurbish deal where it would go through a used Dozer for a price with parks being the biggest customers...
Others are more versed than I am but the C in 350C has wet clutches which are suppose to last longer... I also have the reverser which is like a shuttle for forward and reverse in a given range which means no shifting or clutch which is very nice for trail making...
The size of the 350 just makes the weight rating of my trailer and the Ford Super Duty towing is no problem...
The nice thing about the D3 is the wider blade really enhanced production for things like Fire Trails...
The downside is nothing I had could tow it... both trailer, truck and license...
Someday the 350 I use may need the injector rebuilt... for now it still is earning it's keep and the tracks are good... it was owned by a water department in the Sierra...
For the same price I could have bought a Deere 450 next to it... but went for the smaller package due to my being able to move it.
   / What to look for when buying a dozer help us? #34
Yes and let me tell you, the hardest part was driving that master pin. I lined up the master link on the rear sprocket and made a spacer to go between the inside surface of the track chain and the tractor. I also made a long handle holder to sit over the end of the pin so I would protect the end of the pin from damage and my helper could safely hold the pin in position. The pins are a couple thousandths BIGGER than the hole they go into. I had the pins in the freezer overnight and heated the chain hole before I attempted to drive them. Driving the pin was me swinging a 12 lb sledge hammer as hard as I could, imagine like a baseball bat going for a home run with every swing. The pin would barely move with each hit but I got them in.
   / What to look for when buying a dozer help us? #35
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
Boat (A51694)
Boat (A51694)
2003 Ford F-550 4x4 Terex TL38P 38FT Bucket Truck (A51692)
2003 Ford F-550...
Baker BFD80 8,000lbs Diesel Forklift (A51691)
Baker BFD80...
Adams 5 Ton HC Spreader (A53473)
Adams 5 Ton HC...
