Case Farmall 95 pump or injector troubles.
   / Case Farmall 95 pump or injector troubles.
   / Case Farmall 95 pump or injector troubles. #12
That's how a weak lift pump would act... Hopefully that will fix it...
My neighbor has a JX95 with a cab... It was acting up, and it ended up being a pinched fuel line under the cab.
SR
I had a pinched line too. I fixed it when I replaced all of the line from the filter to the tank.
   / Case Farmall 95 pump or injector troubles. #14
My CIH dealer took the clear line off, replacing it with blk. fuel line... Some years later, the inner blk. line started dissolving, plugging everything up!
I hope you put on the clear line and NOT gas line?
SR
I put on the black fuel line. It is SAE J30R7 grade. It said it is rated for gas or diesel.
???? Hopefully it won't breakdown.
   / Case Farmall 95 pump or injector troubles. #16
I can't help you there... I know that my neighbors tractor now has the clear back on it...
SR
   / Case Farmall 95 pump or injector troubles. #17
Have u ordered the supply pump?? or at least checked the psi??
Did u unhook the cold start device{CSD}
I ordered the pump. It will be here Thursday. I haven't checked the pressure. I had disconnected the cold start device & it didn't seem to make a difference.
So I got the pump yesterday and put it on this afternoon. Ran a lot better but after about 45 minutes it would still sputter when it gets about 2000 rpm.*
The sputtering is not as bad as before. It will bog down until it almost dies the come back up as soon as you let off the pedal.
   / Case Farmall 95 pump or injector troubles. #20
How about with the fuel cap loose? Maybe it's not breathing and letting air in?
SR
LOT: (10) Chairs (A59076)
LOT: (10) Chairs...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
John Deere 3025E (A53317)
John Deere 3025E...
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
2013 International Derrick Digger Truck (A55973)
2013 International...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
