Case Farmall 95 pump or injector troubles.
   / Case Farmall 95 pump or injector troubles.
   / Case Farmall 95 pump or injector troubles. #12
That's how a weak lift pump would act... Hopefully that will fix it...
My neighbor has a JX95 with a cab... It was acting up, and it ended up being a pinched fuel line under the cab.
SR
I had a pinched line too. I fixed it when I replaced all of the line from the filter to the tank.
   / Case Farmall 95 pump or injector troubles. #14
My CIH dealer took the clear line off, replacing it with blk. fuel line... Some years later, the inner blk. line started dissolving, plugging everything up!
I hope you put on the clear line and NOT gas line?
SR
I put on the black fuel line. It is SAE J30R7 grade. It said it is rated for gas or diesel.
???? Hopefully it won't breakdown.
   / Case Farmall 95 pump or injector troubles. #16
I can't help you there... I know that my neighbors tractor now has the clear back on it...
SR
   / Case Farmall 95 pump or injector troubles. #17
Have u ordered the supply pump?? or at least checked the psi??
Did u unhook the cold start device{CSD}
I ordered the pump. It will be here Thursday. I haven't checked the pressure. I had disconnected the cold start device & it didn't seem to make a difference.
So I got the pump yesterday and put it on this afternoon. Ran a lot better but after about 45 minutes it would still sputter when it gets about 2000 rpm.*
The sputtering is not as bad as before. It will bog down until it almost dies the come back up as soon as you let off the pedal.
   / Case Farmall 95 pump or injector troubles. #20
How about with the fuel cap loose? Maybe it's not breathing and letting air in?
SR
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
Mini Margaritaville Truck (A55853)
Mini...
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
2020 CATERPILLAR 306 CR EXCAVATOR (A52709)
2020 CATERPILLAR...
