Buying Advice yanmar 1900
   / yanmar 1900 #11
   / yanmar 1900 #12
Since you had the YM1610, the PowerShift is hard to beat as the YM1900 is manual gear.
On another forum, the YM1900 has better attributes over a Ford 8N.
Yes, I would take a smaller Powershift over a manual any day. In fact I have: the little YM186D will do nearly anything that I used the YM240 for. The larger YM240 is good only for carrying the backhoe, and for when - rarely - I need its larger loader lift ability. The Powershift's ability to shift without making a full stop makes the little guy far more practical in day to day use.
That said, YM1900 or YM2000(YM240) are excellent choices where low initial cost and simple ongoing upkeep are valued.
Comparison to Ford 8N? I studied YM240 vs 8N and concluded they are so different that a choice would depend on the application. YM240 will push more hp out the PTO if that is important. And the Ford won't go slow enough to rototill well. Yanmar has a much lower low gear, useful not only for tilling but for backing a trailer uphill etc where precision is helpful. Rated HP is similar (24 vs 27 engine hp) but I think the diesel Yanmar has more torque at lower rpm so the application determines which serves better. Ford has a huge advantage of weight. Pulling a plow is a natural for the Ford, that's what it was built for, where the Yanmar will spin tires, probably even with a lesser plow.
And not really a theoretical comparison but I think the Ford anyone finds locally may be cheaper but will not be in as good condition as a Yanmar. Bad, oil-damaged brakes on a Ford are common, and a lot of work to repair, while rare for Yanmar. Fuel cost for a gas tractor is much higher. Carb and ignition maintenance are routine parts of owning a Ford, while the Yanmar will run for years, decades, with next to nothing needed beyond the lubricants that both tractors need equally.
The Fords I found locally seemed like one would need endless tinkering for as long as I owned it, same as buying a 1949 model car. Yanmars simply run for years. YMMV!
   / yanmar 1900 #13
I agree on the Powershift, I initially thought it was a "nice-to-have" but after using it on my hilly property, I can never go back. Fantastic for getting going on steep hills and loader work.
   / yanmar 1900 #14
Yes the Powershift is pretty nice I must say. It is nice when using your loader, and I especially like using it when I am tilling and snow blowing.
   / yanmar 1900 #15
I have had mine for about 4 years and really like it. I think it needs rings as it smokes and spits on me! Its a bit hard to start when it's cold too.
I splurged and put new turf tires on it so I could use it more in the yard and it gets much better traction in the snow!
   / yanmar 1900 #16
id say rings is a pretty good bet seeing the visible smoke in that pic sitting there idleling...i assume its not at high idle there or operating speed just sitting for a pic.
   / yanmar 1900 #17
I know that people turn the Exhaust so it's pointing forwards. Esp. for the reason you described, blow bye. Something doesn't look to be in that good of shape were the Pipe connects at the muffler. So you won't be out all that much if you have to shorten it and keep from hitting the FEL.. If it even does. Bolts holes line right up doing that. At least you won't have to dodge all the nukes.
   / yanmar 1900 #18
I turned the exhaust 90 degrees forward - horizontal - and outward on the first YM186D to get under my orchard trees. I didn't like it, I was always breathing too much exhaust. I think a lot of it got into the fan and got blown toward me. For the second YM186D with loader, the loader protected most of it so I left it upright. This is a lot better. I seldom notice exhaust smell. So I wouldn't turn exhaust forward unless there is a particular need to have a low profile.
   / yanmar 1900 #19
I think the horizontal exhaust makes it worse also. I think the ideal solution would be:
   / yanmar 1900 #20
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
17101 (A55851)
17101 (A55851)
LOT: Receiver Hitches, 1/2 Ton Sheet Clamp, Pipe Threader (A59076)
LOT: Receiver...
(2) EVENRUDE OUTBOARD MOTOR (A58374)
(2) EVENRUDE...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
