Kubota M series Seat repair or replacement
   / Kubota M series Seat repair or replacement #1
case580c
Northern California
Kubota M5140 Case 580C, Case 450C, Case 850B John Deere 350C, Kubota L185, Kubota L245H,
I have an M5140HD, I am assuming most if not all the Series M tractors would use the same seat parts. Please correct me if I am incorrect.*
My (new to me) tractor was left outdoors the seat exterior coverings cracked & pieces missing, even the foam cushions under the coverings, are wore away some.*
I could almost just recover them but with the condition of the foam cushions think it is best to replace them.*
I need to take the seat frame componets apart as it will not slide foward or to the rear as parts are froze together.*
I believe cleaning and lubing componets and it will be as good as new, once I install new cushions.
Also the stock folding arm rests need to be replaced
And the small shock assorber (ABSORBER,SHOCK p/n 3C081-85080) on the seat support frame is broken, at end of rod at weld I think I may be able to reweld it as I recall Kubota wants over 190 bucks for just this small shock!
As I see it I can either just replace the cushions or replace the entire assembly,*
Just a matter of costs & time spent
Would like your opinions on where to go for a decent replacement source other than Kubota as they what way to much for a replacemet*
Thanks, Bill
   / Kubota M series Seat repair or replacement #2
Thanks, Bill
I responded to your query on OTT. Unless you want to have a Kubota genuine seat, google" tractor seats" or "Kubota M5340HD tractor seat" and see what you get.
   / Kubota M series Seat repair or replacement #3
Bill - I would try a place like Messicks - they could undoubtedly have replacements. I know there are other aftermarket places - Grammar, Thomas Scott, K&M. These three make aftermarket "normal" AND air ride seats.
However - if I had to replace the seat on my M6040 - I might go with an air ride seat. I don't have a cab but the tractor is stored under cover away from the weather and sun.
It get very tiring - bouncing up/down - in direct opposition the the movement of the seat.
What or where is OTT is it another forum? Sorry but I am drawing a blank
   / Kubota M series Seat repair or replacement #8
There are seats on EBAY from time to time. Many M seats are the same .
   / Kubota M series Seat repair or replacement #9
We've had a local auto upholstery shop rebuild forklift seats for us. They replaced foam and did a really nice job for less than $150.
That's and excellent tip Thanks I will check that out. I might have to drive North a bit as in my area most shops work on high end autos and charge accordingly
2008 Ford F-250 Crew Cab Pickup Truck (A55852)
2008 Ford F-250...
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
2012 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTN6 LIGHT TOWER (A55745)
2012 WACKER NEUSON...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
2013 John Deere 1600 Turbo Wide Area Mower (A54865)
2013 John Deere...
2001 International 4700 Bucket Truck, VIN # 1HTSCABNX1H380565 (A54865)
2001 International...
