Kubota M series Seat repair or replacement
/ Kubota M series Seat repair or replacement #1
case580c
Northern California
Kubota M5140 Case 580C, Case 450C, Case 850B John Deere 350C, Kubota L185, Kubota L245H,
I have an M5140HD, I am assuming most if not all the Series M tractors would use the same seat parts. Please correct me if I am incorrect.*
My (new to me) tractor was left outdoors the seat exterior coverings cracked & pieces missing, even the foam cushions under the coverings, are wore away some.*
I could almost just recover them but with the condition of the foam cushions think it is best to replace them.*
I need to take the seat frame componets apart as it will not slide foward or to the rear as parts are froze together.*
I believe cleaning and lubing componets and it will be as good as new, once I install new cushions.
Also the stock folding arm rests need to be replaced
And the small shock assorber (ABSORBER,SHOCK p/n 3C081-85080) on the seat support frame is broken, at end of rod at weld I think I may be able to reweld it as I recall Kubota wants over 190 bucks for just this small shock!
As I see it I can either just replace the cushions or replace the entire assembly,*
Just a matter of costs & time spent
Would like your opinions on where to go for a decent replacement source other than Kubota as they what way to much for a replacemet*
Thanks, Bill
/ Kubota M series Seat repair or replacement #2
Thanks, Bill
I responded to your query on OTT. Unless you want to have a Kubota genuine seat, google" tractor seats" or "Kubota M5340HD tractor seat" and see what you get.
/ Kubota M series Seat repair or replacement #3
Bill - I would try a place like Messicks - they could undoubtedly have replacements. I know there are other aftermarket places - Grammar, Thomas Scott, K&M. These three make aftermarket "normal" AND air ride seats.
However - if I had to replace the seat on my M6040 - I might go with an air ride seat. I don't have a cab but the tractor is stored under cover away from the weather and sun.
It get very tiring - bouncing up/down - in direct opposition the the movement of the seat.
What or where is OTT is it another forum? Sorry but I am drawing a blank
/ Kubota M series Seat repair or replacement #8
There are seats on EBAY from time to time. Many M seats are the same .
/ Kubota M series Seat repair or replacement #9
We've had a local auto upholstery shop rebuild forklift seats for us. They replaced foam and did a really nice job for less than $150.
That's and excellent tip Thanks I will check that out. I might have to drive North a bit as in my area most shops work on high end autos and charge accordingly
/ Kubota M series Seat repair or replacement #11
We've had seats built and rebuilt by a shop that does small airplanes. Price was much better than an auto shop.
