LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,307
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Well I'm going to disagree,
I have a 10 ft back blade,
a 8 ft SSQA blade to mount onthe FEL,
and of course the bucket.
I also have a truck with an 8 ft Fisher blade.
Depending on the storm and the condition of the driveway will decide what I use.
If the driveway is soft and it's just 2-3 inches I will actually break out the York rake,
4 inches plus if the driveway is soft and thawed I'll use the blade on the FEL as I'll go slow and can see what the cutting edge is doing.
Once the driveway is froze hard, I'll use the back blade while driving forward to scrape it clean,
the back blade doesn't work good in the corners or to push across the road or into my turn off,
so I'll use the bucket or front blade to clean the corners and road crossing.
The front blade is a bit nicer then the bucket for that, but if I am going to need to sand I'll need the bucket to load with I'll leave it on.
So the nicest when the ground is set up is the 2 blade setup, the rear for the most the front for cleanup.
Also I use the blade or bucket when we get lots of snow to push the snow banks out of the way,
the blade is a bit faster for that.
My driveway seems to always be rough and I plow slow 3-6 mph.
