What did you do to or on your Mahindra today?
   / What did you do to or on your Mahindra today? #532
Moved the last of the ash from my driveway and a couple truck loads of locust. Finished it before the snow started fallling. My to labs helped keep me company and even wanted in a few pics. I ended up greasing the loader arms and grapple last night as well. Just went over 130 hours after todays work.
   / What did you do to or on your Mahindra today? #533
That's awesome! Love it.
   / What did you do to or on your Mahindra today? #534
Made a payment on a tractor that I am unable to use right now. It is in the shop for repairs.
What kind of repairs? I own a 2555 with 250 hours and the PSU (power steering control valve) was leaking, so I removed it for repairs. It's made in Korea and there are no Mahindra parts available for this. They tell you must purchase a new PSU, only $1,100. I was told they will leak also, maybe in 100 hours. I'm rebuilding my PSU with seals purchased from seal companies. I hope it works. The seals cost less than $30.
   / What did you do to or on your Mahindra today? #535
Is everyone using the Mahindra brand grease? If you're not, what type are you using?
I use Tractor Supply grease. I look at the temperature ratings on the tubes. I buy a high temp for PTO shaft U-joints and other higher temp areas on the tractor. I use a general purpose grease on the loader. Or, I buy what's on sale. It's does make a difference, but very little. Maybe just in high temp areas.
I built racking in my outbuilding. First level is 5'6", second level is 6'5", 16 feet wide and 8' deep. I now have an place inside, for all implements with moving parts , and my woodsplitter, without losing a ton of floorspace. Put the big grapple, little grapple, PTO splitter, regular splitter, and wood chipper in the new storage area. Used the forks on the 2538 to get some of the items up to the second level.
   / What did you do to or on your Mahindra today? #537
Please post pics!
   / What did you do to or on your Mahindra today? #538
I spread 16 yards of asphalt
   / What did you do to or on your Mahindra today? #539
Dragging a 24 foot pipe drag to knock down gopher mounds and break up cow patties.
SB98iJ32KoD1Z9D_S1yO2ky-t3ZJTekoyMEi6EfAeI0j5Ci8jzst1RqBRfDsqlkxQnSyida3dfzs2bGNvd3C-wsxYjbEzHEY4C92zgkm_hcYdoX1KhNat3vR1pUNGUDpQOrKayBJrwfrtRDqxw9lEvgmv8WjwLPJSEmaqaTLqXbGlCkeVGihk9-hqpR9gNSLJScjzPgE4lD_Uo0ASSQNF2teYDtpwj2xrmbTGQGDXHFgKUmpXMDjVnWVEGAnNgsfKOIXbqI_kxyqUZHKLQArA2btFZiyxG6UgeaUuPm2LoYOczb_D4St1P4OI2sFtGmVyuA1vyy3qoxU9eBPnbbFiFxPKJySJyly2eDuI9y12Gl6x9aLBHk7DmMqbqTOeLE0RhCQjt5omSF2H1Jvlc7qYCwJSOngCOupieOaXx79JXXKg4XYpQfIOc1y4N0EDPrpPGN7LvLQpu9xs_Snzor4IpmGiWs68gPs8iiCJX4R0OD2W9dEiF-xqJmtS6ncwhaEq_EuowWCRvcCHE5x9fixAQJmdg5rEWHlDOpHBil1dx32Iezw6NJ-IF96d3T5nhJLSWFKqLhSKlZupJ31f0QYd-7rhpX6D_oO0VnnY25aaitCcLQ9ogJCFyGib5r8kTh37A8LI-cJ0SYeY-_9u-u7rEK2NnMpLxpR=w500-no-tmp.jpg
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2019 FREIGHTLINER...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2002 International 9200i Truck (A55315)
2002 International...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
