What did you do to or on your Mahindra today?
   / What did you do to or on your Mahindra today? #501
That sounds like a good idea. Thanks for that!
   / What did you do to or on your Mahindra today? #502
I bought a box of bright red, orange and yellow zirk covers so they stand out and are easy to locate when I'm ready to grease. I've lost a couple while working, but for the most part they've stayed on.
   / What did you do to or on your Mahindra today? #505
I am...not bc I'm loyal to it, just bought a lot from the dealer when I got the tractor. Once that supply is out,I'll probably use something from RK or TSC.
   / What did you do to or on your Mahindra today? #506
I use Permalube heavy duty multipurpose, and lucas the green heavy duty and red tack. That's because I have cases of each. As long as you grease it when it needs greased, I don't think it matters much as long as it is a good grease. But what is a bad grease? My brother is a mechanic and works on equipment and he always say's just use grease it doesn't matter what brand just what is recommended for the thing being greased.
   / What did you do to or on your Mahindra today? #507
Grease must be a fairly recent addition to their lineup. When I purchased my tractor, they had just started labeling their own hydraulic fluid and that was all they offered.
That being said, I use "Texas Red" (I think that is the name) on high speed parts such as PTO shaft universal joints. On loader/hoe pins and similar high pressure parts, I use the Tractor Supply Traveller brand black heavy duty high pressure moly grease.
   / What did you do to or on your Mahindra today? #508
We cleaned up some dead trees and stumps we had pulled, stacked them on a burn pile and box bladed the stump holes.
-UeHB41XfwOHbY0Un2BVSvUqzc8vV5VHptA4-dC3B4QzTHFwV2kXS7i2unAAeSFtI6suxZMYWNuSpioeMtktHhaZd7WCue9XSAdwoowGSIS5avr0fIN4ahFzMCrlG1PU4n00G6xGKb7tJ3L1i5C73eLLxJW8GoNFMP4th7dsR-6xqR6qbbH3AEtuT3GGPV4VOWZsXvoMUu6d3mcveh1viUkEfjSWdyAoJ0jdAVf45cO5pTqubZ5hD_YeYKmIYBgXwhgGgIaegLRhsZ0kq3VdpQAmY9BkExRuvZ1R2ZWobRR_gqQSGrOpINczWciFmKCn9QrWxWtfwe0T8C6FKS0HpERuOAEttXysV89tbbZdTaFI0mjVSc7H2l5kVl0nMPMal1EHChW12cfnuCT9OfyERp4yHRVCIu-KVWxVmD-M3QP8y3mbO36kwNPK7jiSGDnkXGrIXekcmnooby69jH2q_2GFqVyEZ4BJZTAF313yYvgOr_nI6gpe7vK3A8KXvFkZYVwbGNKeCUS6kZifS1q2UeyOn_g44t7F4WA-xYS6ma33bgChlgivgec1wcPx1U4dJTsoUSNdQybL3SAllEWLfAva6aq09dplainE3u2xLZFZNOHYnqHHF54nt3VUnLKQ68XxbXs01Xwosl6NAHKMZHTSGg=w500-no-tmp.jpg
-f49XMtOhsMtT2f_czKZTq3V--Yhd3baJ1M0aJ2dNLXnJLRvZndtYVpqNlKrUcWzi3rR1o-Vgg2xOMf-RPa3gYCTJSlD9zscvrlqs70YtDsip3Zog5L-kUkJ8ji5u0ytmgFf9C2SqUjoMLTrgOUGHiXqo7vqLoHFu5eMNGQziv4YSDuFWAWyHwiQeQidHq5lW4gO5SGRWKATdA3Hk1YDjGr3tkxeVYXS8UwDOxQhn-hoOkUw9yVDFvOuQOdDhZxkKnUid9UQugbTihuPMrSkG7f_zYmwNrHNUsmNvAvJeApAX4QVkW5eBKMhTp5rJOl137jV9EDftzL_ZVPBXz_SpuFD2n6xGXW7JkYCGTBwpQDZfpM0qvGDe3DVL_cDR_GElX2Ldqa3-jFpaysfi_4ZloWkBdwI_x90Du8ECftn2thjbL4OD26DNolE0urfQMX9aAfb7cf0hqRXnvsCKdGLdctPYcTWgmbv433CJ0xtSVXLjwxSqMeR_CNydg5a40x4g96gTJsF7Tk5I1QJ55RfX_6GrUrfeT3mvD-jXq5z4SM4sNYHoTZsPRrduuAobZN1oAko0dO1Sy32qtdn2LwtMOrdCT4i8_HVjN0hzAsf7bj1s1K2JD6qIBksjYW8HPhpF-M2xHCXOeiqXNSZCPUnqnLt1A=w500-no-tmp.jpg
   / What did you do to or on your Mahindra today? #509
@mad Mac, been there done that. Lol. I used my 4540 to clean up where I had some guys grind 30 stumps. So I used the bucket to fill in the holes and smooth out the dirt.
   / What did you do to or on your Mahindra today? #510
Finally located some boulders that were close and a good price: FREE.
Picked two of the four that could be picked up. The one above is the larger of the two, but not by much. I figured about 1100lbs and needed extra balast to keep the rear wheels on the ground. The smaller one was just under 1000lbs and was handeled but the extra balast made it safer. The two remaining boulders are still there. Although I can drag them I think they top a ton a piece. No way I can get them into a trailer.
Put them at the end of a driveway for "Protection". The mail box was taken out twice. I told the owner that this would not protect the mailbox but keep the car from driving away.
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
DEUTZ MARATHON...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2024 JOHN DEERE 250P EXCAVATOR (A60429)
2024 JOHN DEERE...
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
